Does anyone know of an interchange for the Multifunction switch used in a Column Shifted 91 Comanche? Quite sure they switch was used in other cars.
John Jackson
91 long bed w/big ton package
tilt, non-tilt column; delay wipers?? I got mine for my 91 column shift w. non-tilt and delay wipers from Turner 4WD. Best price I could find. Been working well for 4+ years now. :cheers:
So, the stalk is called a mult-function switch? I didn't know that. I do know that newer Grand Cheokees have a multi-function switch. The turn signals and wipers are in on self contained switch package.
Mac..
older chevs contained the same ones if that helps any.
Think we found one in Alabama, should get here by Tuesday. Did know Jeep got a lot of parts, including steering columns from GM. But did not think to search the forums for posts about steering columns. Just searched for the term "multifunction switch".
So, the stalk is called a mult-function switch? I didn't know that. I do know that newer Grand Cheokees have a multi-function switch. The turn signals and wipers are in on self contained switch package. Mac..
No, the MF switch is embedded in the column in the older columns. The stalk is the actuator and plugs into it. Both come in several varieties and flavors depending on which Saginaw column and options. :cheers:
