MjAllTheWay Posted April 22, 2010 Posted April 22, 2010 I'm confused on how you measure lift i pretty much made a lift but i don't really know how much i have i would like to know if i could fit 33s and what sway bar to go with so any answer are help full thanks.
Eagle Posted April 22, 2010 Posted April 22, 2010 If you still have the factory flares, measure from the centerline of the wheels/hubs/axles stright up to the bottom edge of the flare. Stock height for an MJ should be approximately 17-1/2" front and 20-1/2" rear. If you don't have the factory flares, I've posted the official factory method of measuring a couple of times, and a search should turn it up.
MjAllTheWay Posted April 22, 2010 Author Posted April 22, 2010 Sweet man i do have factory flares so i should be good.
MjAllTheWay Posted April 22, 2010 Author Posted April 22, 2010 Dose anyone know how much lift it takes to fit 33s
Pete M Posted April 22, 2010 Posted April 22, 2010 there are lots of variables involved like backspacing and trimming, but typically 5 inches or so. Got the gearing/axles to support the bigger meats?
MjAllTheWay Posted April 23, 2010 Author Posted April 23, 2010 Well i have 3.55s should be good to spin the 33s i don't see any problems
Pete M Posted April 23, 2010 Posted April 23, 2010 have you experienced 3.55s and 33s yet? I've got 4.10s and wish I had 4.56 or 4.88 gears.
mnkyboy Posted April 23, 2010 Posted April 23, 2010 I have 3.55s and 33s with a 2.5L it sucks. My XJ has a 4.0L aw4 and 3.55s with 31s and it could use gears. I imagine 33s would suck and i wouldnt expect very good fuel mileage either
mvusse Posted April 23, 2010 Posted April 23, 2010 I have a 4.0/auto and 33s with stock ratio sucked. I now run 35s with the stock gears and overdrive is useless. Drove a friend's Cherokee on 33s with 4.10 gears (also 4.0/auto) and it's about the same as stock gears on stock tires. haven't had a chance or funds to go to 4.10 yet. When I do my current axles are going into Booger, which currently has the stock 3.07 ratio.
MjAllTheWay Posted April 23, 2010 Author Posted April 23, 2010 Sweet guys thans for all the help I'm going to measure my rig today and see how much lift it has and i don't really know if 33s will be in the future but i might jest go buy some maypops and see what it looks like and drives like.
Eagle Posted April 23, 2010 Posted April 23, 2010 Sweet guys thans for all the help I'm going to measure my rig today and see how much lift it has and i don't really know if 33s will be in the future but i might jest go buy some maypops and see what it looks like and drives like. Keep in mind that width is as much of a problem (or more) regarding clearance for large tires as diameter. 33s come in various widths, and unless you really need fat, wide tires to float over sand, you can probably do better and need less lift with the narrowest tire you can find. These days I think that may be a 33 x 10.50, but a few years ago at least one company offered a 33 x 9.50 that we called the "pizza cutter" tire. It worked great.
MjAllTheWay Posted April 24, 2010 Author Posted April 24, 2010 Well i measured my truck and its 23and 1/2 inches in the front and 24 and 1/2 in the rear so I'm thinkin about a 4 inch lift.
Eagle Posted April 24, 2010 Posted April 24, 2010 Well i measured my truck and its 23and 1/2 inches in the front and 24 and 1/2 in the rear so I'm thinkin about a 4 inch lift. 23-1/2 minus 17-1/2 does not equal 4. It equals 6.
comanche09 Posted April 24, 2010 Posted April 24, 2010 If you still have the factory flares, measure from the centerline of the wheels/hubs/axles stright up to the bottom edge of the flare. Stock height for an MJ should be approximately 17-1/2" front and 20-1/2" rear. I'm running XJ Upcountry Springs in the front under two (2) spring isolators and get 19", 3" Motion Offroad standard load lift leaves out back for a measurement of 22". The lift leaves are only netting me 1.5" off lift :hmm: I do have a cap on the back though... Anyone have objections to throwing a 2" spacer sandwiched between the two isolators up front?
Pete M Posted April 24, 2010 Posted April 24, 2010 If you still have the factory flares, measure from the centerline of the wheels/hubs/axles stright up to the bottom edge of the flare. Stock height for an MJ should be approximately 17-1/2" front and 20-1/2" rear. I'm running XJ Upcountry Springs in the front under two (2) spring isolators and get 19", 3" Motion Offroad standard load lift leaves out back for a measurement of 22". The lift leaves are only netting me 1.5" off lift :hmm: I do have a cap on the back though... Anyone have objections to throwing a 2" spacer sandwiched between the two isolators up front? what else are you doing to accommodate the extra 2"? control arms? shocks? track bar? brake lines?
comanche09 Posted April 24, 2010 Posted April 24, 2010 If you still have the factory flares, measure from the centerline of the wheels/hubs/axles stright up to the bottom edge of the flare. Stock height for an MJ should be approximately 17-1/2" front and 20-1/2" rear. I'm running XJ Upcountry Springs in the front under two (2) spring isolators and get 19", 3" Motion Offroad standard load lift leaves out back for a measurement of 22". The lift leaves are only netting me 1.5" off lift :hmm: I do have a cap on the back though... Anyone have objections to throwing a 2" spacer sandwiched between the two isolators up front? what else are you doing to accommodate the extra 2"? control arms? shocks? track bar? brake lines? Hi Pete! I've got a rough country adjustable track bar (the $99 one with OEM type ball joint), YJ monroe shocks ready to put in (just have to press in the bar pins) and YJ brake lines are installed. I've ordered Adj lower controls arms from Arc Fabrications with rubber bushings installed in place of the poly ones ($155 shipped). Contemplating ordering their adj upper arms with rubber bushings ($135 shipped). May have some ready to go WJ upper and lower arms for sale. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330418057061&ssPageName=STRK:MEWAX:IT Not building a rock crawler (no rocks in S. Alabama!). Just a woods/ rough trail truck, and I prefer to avoid mud hehe. Heard anything about Arc Fabrications? Their customer service seems second to none in my experience. EDIT: I really like the ride of the Upcountry springs and thats why I want to keep them, (plus its cheaper!) I've heard of problems with spacers slipping and springs binding. Would I be ok with a 2" spacer sandwiched between to isolators?
MjAllTheWay Posted April 24, 2010 Author Posted April 24, 2010 Ya but mine dosent look like that much of a lift. ya i don't want a rock crawler but jest a real good trail truck that can do anything i need it to.
MjAllTheWay Posted April 24, 2010 Author Posted April 24, 2010 I think it has good travel too hear it is up on the lift.
