jpdriver1 Posted April 2, 2010 Share Posted April 2, 2010 anybody discovered any shortcuts or secrets to replacing the ebrake cable & mechanism? thanks in advance :bowdown: Link to comment Share on other sites More sharing options...
rcturgeon Posted April 2, 2010 Share Posted April 2, 2010 actually I'm trying to swap mine out too.. i did the rear, obviously not to hard but i've got the foot break for the front so the only real option is to remove the seat and some plastics and the edge of the floor mats. And becasue both ends need to feed through something and there are little metal tabs that hold the cable down so theres no way to attach and pull through or anything like that sorry i know its a pain, I'm doing the exact same thing Link to comment Share on other sites More sharing options...
BORDENCOMANCHE Posted April 2, 2010 Share Posted April 2, 2010 brute force? Link to comment Share on other sites More sharing options...
jimoshel Posted April 2, 2010 Share Posted April 2, 2010 Only brutes use brute force. Gentlemen use a BFH ! Link to comment Share on other sites More sharing options...
maddzz1 Posted April 2, 2010 Share Posted April 2, 2010 If your MJ is like mine, and has no floors, you may be able to do it w/out removing the interior. My seat actually tilts toward the door :eek: Link to comment Share on other sites More sharing options...
glundblad Posted April 2, 2010 Share Posted April 2, 2010 It has been awhile but it seemed to me the easiest way to get to parking brake for me was to remove the lower panel of the dash. Then I vaguely recall something about a brace for the dask or steering wheel that I removed. Remove the kick panel of course. After that, you only needed to be small, nible and double jointed. Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 3, 2010 Author Share Posted April 3, 2010 good thing I've set aside three days to do this eh? thanks guys Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 17, 2010 Author Share Posted April 17, 2010 well small, nimble and dbl jointed I ain't -- took longer than I thought. with the 10 inches of rain so far this yr, the pad under the carpet was a small swamp. got it done though -- both the cable and the mechanism -- need to re-attack the fuse panel -- got no turn signals now -oh well ebrake cable number ac delco #18P668 via http://www.rockauto.com BTW -- the floor pan was still mint --- yahoo desert truck :banana: Link to comment Share on other sites More sharing options...
rcturgeon Posted April 18, 2010 Share Posted April 18, 2010 good thing I've set aside three days to do this eh? thanks guys i just did mine in all of an hour, but i re did the floors too and that took me about a day and a half, longest part was waiting for the carpet stuff to dry out Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 18, 2010 Author Share Posted April 18, 2010 yep -- that mat was worse than a sponge Link to comment Share on other sites More sharing options...
