bed plugs
how do you remove them? Can you put them back on once removed? Also, anyone have an extra frame support for the roll bar laying around?
They are "glued" in. Use a stiff putty knife, hammer it under the edge and work it all the way around, except the ends where the tabs are located (underneath), I also bent the large tab to vertical from underneath and scraped the adhesive away. Should end up like this.
They are not for drainage. The drain holes are at the bery front of the box, where the front wall meets the floor. Look closely and you'll see three crimped sections that form scuppers to allow water to drain out toward the cab.
