At my school, I have access to Mitchell OnDemand on the school PC's.
So, anybody needs info mon-friday, I can get it for them from the mitchell-ondemand.
Enjoy, 'cause this will last until the course finishes in January
What is mitchell used for? I ask because I work at a drag racing shop and I have access but never have used it. :dunce: :dunno:
we have it at my work. its pretty useful to have around especially for the little things like wiring and vacuum diagrams. It also gives some instructions and specifications.
its kinda like a service manual for every car possible
so could you get me the vac diagram for the 4wd for a 91 eliminator? i think it has a vac leak since the CAD won't engage. also if it has the wiring diagram for the lights for the rollbar to the dash switch that would help too. also i could use the ones for the cherokee waggy control center that is under the LCD clock and one for the overhead temp/compass. thanks.
Alex
Mitchel on demand is like a haynes on steriods and it gives great info and diagrams. I can "GET" access at certain times but not steady and not for the next 4 months since the guy i "get" it from is deployed. We have used it alot and it is so much better that a chiltons or haynes IMO it goes into alot of detail because its for mechanic shops to use. :cheers: enjoy it while it lasts. ;)
Oh yeah and any projects you plan to tackle go ahead and print off anything you might think you need for later since you want have access long. :D
Cole
Alex
check your pm's pal. Got yah what I could.. I'm extremely tired and will give'r a nother shot tomorrow
Alex
Will this help
