Mitchell OnDemand5
so could you get me the vac diagram for the 4wd for a 91 eliminator? i think it has a vac leak since the CAD won't engage. also if it has the wiring diagram for the lights for the rollbar to the dash switch that would help too. also i could use the ones for the cherokee waggy control center that is under the LCD clock and one for the overhead temp/compass. thanks.
Alex
Mitchel on demand is like a haynes on steriods and it gives great info and diagrams. I can "GET" access at certain times but not steady and not for the next 4 months since the guy i "get" it from is deployed. We have used it alot and it is so much better that a chiltons or haynes IMO it goes into alot of detail because its for mechanic shops to use. :cheers: enjoy it while it lasts. ;)
Oh yeah and any projects you plan to tackle go ahead and print off anything you might think you need for later since you want have access long. :D
Cole
Alex
check your pm's pal. Got yah what I could.. I'm extremely tired and will give'r a nother shot tomorrow
Alex
Will this help
