Soft front Springs, Your valued opinion...
I have 3" Superlift front springs and they are to stiff for me.
What 3" springs are softer and provide a nice on-road ride?
I have read through posts but I am not convinced after reading.
Specs for the springs would be great but most companies don't post this info. :nuts:
I don't have a heavy bumper or winch and really don't plan on it so the lightest springs compared to factory would be great!
Thanks for all your help in advance.
I am using BDS 7500 series shocks. The shocks seem to handle good, but I haven't given thorough drive test yet.
There is a listing for a 3" spring on the OME site, but what spring rate is the HD one? The earlier reading says 148lb, but that does not mention the HD springs. I really don't think I need HD springs so can I buy regular 148lb springs with a 3" lift?
Thanks,
Here is a bit of info to help you decide (info provided by each manufacture directly);
OEM XJ Coil - 145
BDS 3" XJ Coil - 240
DPG 5" XJ Coil - 198
OME 930 XJ Coil (aprox 2") - 160
OME 934 ZJ Coil (aprox 3" on XJ) - 180
TeraFlex 3.5" XJ Coil - 170
TeraFlex 4.5" XJ Coil - 200
Rustys 3" XJ Coil - 150
Rustys 3" HD XJ Coil - 180
Rustys 4.5" XJ Coil - 150
Rustys 4.5" HD XJ Coil - 180
Rustys 6" XJ Coil - 180
Rustys 9" XJ Coil - 180
Rubicon Express 3.5" XJ Coil - 241
Rubicon Express 4.5" XJ Coil - 169
Rubicon Express 5.5" XJ Coil - 185
Rancho 2.5" XJ Coil - 235
Skyjacker 3" XJ Coil - 218
RockKrawler 3" XJ Coil - 180
RockKrawler 4.5" XJ Coil - 180
RockKrawler 6" XJ Coil - 180
Motion Offroad 3" XJ Coils - 165
Motion Offroad 4.5" XJ Coils - 165
Motion Offroad 6" XJ Coils - 165
REMEMBER THAT THE COIL SPRING RATE DOES NOT DETERMINE 100% OF RIDE QUALITY!!! IT VARIES GREATLY BASED ON THE SHOCKS YOU RUN!!! NOT TO MENTION CONTROL ARM ANGLES!
Thanks,
I've been using the OME 930 coils (together w. OME shocks) for about four years now. By using doubled up stock spring pads, the front lift was a mite over 3". And LEAD is exactly right saying:
