Jeepcom23 Posted January 9, 2010 Share Posted January 9, 2010 I just bought some hockey stick style door handles for my mj from a junk yard, and I need a really good cleaner. Any help? Thanks! -Cody Link to comment Share on other sites More sharing options...
DJM/78 Posted January 9, 2010 Share Posted January 9, 2010 Sweet truck by the way ! I used allot of different cleaners but if you experiment with a couple of soap / water mixtures that works pretty well . My door panels where terrible , none of that worked so I used Gumout " carb and choke cleaner !! That shiz will take anything off, however bleaching the surface a shade or two . Looks good though , for door panels with no hope . :chillin: Here is a pic of mine : Link to comment Share on other sites More sharing options...
mfpdm Posted January 9, 2010 Share Posted January 9, 2010 I use Purple Power on just about everything. It's an industrial strenght degreaser and can be found at most autoparts stores, Target, Walmart, etc. You just need to be careful on some surfaces because it will remove paint. Follow the mixing instructions and make sure you rinse it off good. When doing my door panels, I tried to make sure not to hose down the backing too much. I generally use a soft to medium bristle brush depending on what I'm cleaning and do the apply scrub rinse, apply scrub rinse method. :cheers: Link to comment Share on other sites More sharing options...
Jeepcom23 Posted January 9, 2010 Author Share Posted January 9, 2010 thanks guys, ill try both, ive got some purple power, but I was ust curious if there was anything better. Oh and DJM, I havent forgot about you, ive just been really busy working. Thanks! -Cody Link to comment Share on other sites More sharing options...
jimoshel Posted January 9, 2010 Share Posted January 9, 2010 Always use soap an water first. And elbow grease. If that don't do the job then the chemicals. The trouble with older machinery is fatiqued materials. It's b*tch to spray an irreplaceble piece of fabric or plastic with a modern 'hotshot' miracle cleaner and watch it dissolve or disentegrate before your eyes. I've had good luck with these new wipe towels that's out. Link to comment Share on other sites More sharing options...
satyr36 Posted January 13, 2010 Share Posted January 13, 2010 i can't wait until summer to really give mine some elbow power! Link to comment Share on other sites More sharing options...
jeepcoma Posted January 13, 2010 Share Posted January 13, 2010 Also be sure to try a few scrubbers with different textures. Some fit in the nooks and crannies of the surface you're cleaning better than others. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 13, 2010 Share Posted January 13, 2010 Personally, I like Simple Green for dirt and smudged on mechanic hand grime. Simple Green was also making a heavy duty de-greaser which worked great on general engine bay crap...and it didn't make my yard smell like a refinery. Purple Power is great also. I too, find I have to be careful sometimes to not peel off paint or finish. Link to comment Share on other sites More sharing options...
87Warrior Posted January 13, 2010 Share Posted January 13, 2010 Personally, I like Simple Green for dirt and smudged on mechanic hand grime. Simple Green was also making a heavy duty de-greaser which worked great on general engine bay crap...and it didn't make my yard smell like a refinery. I love simple green, I use it on everything. From the interior to the garage floor to the engine bay. Use a good scrub brush or textured sponge and there is not much that will stand in the simple green's way. Link to comment Share on other sites More sharing options...
dunl Posted January 14, 2010 Share Posted January 14, 2010 Simple Green all the way. :) Works great on whites in the laundry too, if you didn't know.....helps with getting the wife to purchase it for you. (if you don't believe me, try some) Link to comment Share on other sites More sharing options...
comanchedude Posted January 17, 2010 Share Posted January 17, 2010 Westlys bleach white works great on door panels and vinyl/leather seats.. have used it for years. Link to comment Share on other sites More sharing options...
Blue XJ Posted January 17, 2010 Share Posted January 17, 2010 I've had good luck with the Mr Clean Magic Erasers as well. Link to comment Share on other sites More sharing options...
