parking light / dashboard light / headlight problem
my dashboard lights
headlights and parking lights are out
i checked all the fuses under the dash
they kicked on once when i was fumbling around down there (by the fuses)
but then.......nothing
all the fuses are good
is there some relay or other fuse that i should check?
if so, where are they located?
thanx in advance :bowdown:
It would seem that it has to be related to the switch. The instrument lights and the taillights are fused, but the headlights don't run through the fuse panel, they are fused by the built-in circuit breaker in the headlight switch. So if you lost all of them at once, a bad fuse or even a bad fuse panel seems unlikely.
You said that you replaced the headlight switch recently...did you check the single ground wire that goes from the headlight switch harness to the dashboard? It fastens to provide the ground for the switch and all the lights up front (as well as the grounds in the inside front right (drivers side) fender.
Secondly, if you pull the headlight switch with the vehicle off do you get the "buzzing" from the fuse panel? (if you replaced your seatbelt sensor with a more modern one it will buzz when the lights are on without the motor.
Third, did you happen to install a headlight sentinal timer lately, and if so, temporarily remove it from the circuit and see if that helps.
Lastly, (for the interior lights only) check your interior light door pins - they may be crushed and shorting out.
Good Luck! :cheers:
ya that grounds are all good
the headlights are fine, working like they always did
this didnt happen with the motor switch cuz after i ran it all day it worked perfectly, then they went out
like i said before in previous thread,
when i noticed they were off, i started poking around in the fuse panel and they kicked on for a sec, and the buzzer also, which is wierd cuz it never comes on...then, nothing
i got it home checked all the fuses and even tried to wiggle the wires a little to see if would kick on again...nothing
power to the fusebox, and just to be sure i checked all the fuses and they all got power
its just the dash lights and the parking lights
:rant: :rant: :rant: :rant: :rant: :rant: :rant:
