M357.5 Posted September 19, 2006 Posted September 19, 2006 Anyone know if the ZJ V8 motor mounts will bolt right into an MJ ???? I am swappin in a 318 and if factory mounts bolt up it would save time fabbin some up. Never really looked at the 6 Cyl mounts in a ZJ but I am assumeing they are the same as an MJ so it shouldnt be a problem retrofiting the V8 mounts.
Pete M Posted September 19, 2006 Posted September 19, 2006 I'm guessing no. The ZJ and MJ frames don't share any pieces. I'm not saying there isn't a chance, I'm just guessing that they won't bolt up.
M357.5 Posted September 19, 2006 Author Posted September 19, 2006 But the ZJ and XJ/MJ all had the 4.0L and the front suspension is the same....so you would think the motor would be located in roughly the same location. Anyone know for sure ??? If not , no big deal. My cousin has a ZJ limited with the 5.9L in it.....I'll just check his out next weekend. :D
DirtyComanche Posted September 19, 2006 Posted September 19, 2006 Maybe. Maybe not. I'd ask the ZJ guys. Hmmm, www.mallcrawlin.com would be the better bet. The front ends are VERY similar.
Hot Rod Jeep Posted September 19, 2006 Posted September 19, 2006 Shouldn't be too hard to fab up some mounts if you have to. I think I used 4" flat stock for mine. I just shaped it as I needed it. 8)
