can someone that either owns a Metric Ton model, or that has MT springs give me a ground to bottom of rear flare measurement? everything must be stock height, tire, flare wise.
from the ground? that's what he's looking for.
From center of hub. To many variables w/tires (aka tire size, mud/street, how much air, etc) when measuring from ground. When you measure from center of hub tires do not matter.
Measuring from the ground is an invalid reference. Center of hub to lower lip of flare completely eliminates variables due to tire size, tire wear, and inflation pressure. 22" for a Metric Ton sounds about right.
I get 20-1/2" w. MT springs. Must be the big old shell...........
