Pete M Posted September 26, 2006 Posted September 26, 2006 The 2.5Ls are very sensitive to increases in tire size. Also, make sure your cat isn't plugged up.
ridergoatee Posted September 26, 2006 Posted September 26, 2006 3:56 's best for 31"s.correct?Thanx.........ko
Pete M Posted September 26, 2006 Posted September 26, 2006 I assume you mean 4.56? That should be good for a 2.5L and 31s. Personally I go right to 4.88s, but that's just me. :D I prefer deep gears over driving 80 mph.
JOMJ87 Posted September 26, 2006 Posted September 26, 2006 I ran 31s with 3.55 gears and it did ok flat but don't try hills also you will loose 5th gear almost completely. I have 4.10 with 35s and its about the same but it does ok for where i drive because i hardley take it off base so it don't get above 40 mph that much. :D Cole
Scott86mj Posted March 28, 2024 Author Posted March 28, 2024 On 9/13/2006 at 8:12 PM, Scott86mj said: just trying to post a pic/uploads/archive/9cc1322265318b2e0eb24233a6ae87f0/d6799308791456e844f5456f22bf6ecf.jpg I still have this Comanche 18 years later, I'm working on setting it up for mostly trail use but I will be able to drive it to the trails. I have 4.88 gears, air lockers, long arms and 36" SS Irocs with bead locks. Axles are d44 from an Isuzu rodeo and d44 from a grand wagoneer ( still on the bench). It has been off the road since 2009. Plan is to build some kind of flat bed with roll bar.
Salvagedcircuit Posted March 28, 2024 Posted March 28, 2024 Awesome project resurrection! Welcome back
Scott86mj Posted March 28, 2024 Author Posted March 28, 2024 17 hours ago, Salvagedcircuit said: Awesome project resurrection! Welcome back Thanks, I'll try to post the progress!
Scott86mj Posted March 30, 2024 Author Posted March 30, 2024 On 9/16/2006 at 8:42 PM, Scott86mj said: No I could not drive it every day I have a 2003 ram2500. Also I'm going to change the interior color to grey. How about those maroon buckets./uploads/archive/9cc1322265318b2e0eb24233a6ae87f0/868e7f5028e6ec62fca9ad3d8fa77ef4.jpg Looking through this post I still have this truck too!
Scott86mj Posted October 27, 2025 Author Posted October 27, 2025 Finally got to drive the MJ again. Posting a few progress pics. I ended up installing super duty axles and 38's
Big_Mark Posted October 27, 2025 Posted October 27, 2025 Looks like a great "Hammer-Mobile" the only thing I'd suggest adding is rocker skids, that way it'll stay looking good!
Scott86mj Posted October 27, 2025 Author Posted October 27, 2025 10 minutes ago, Big_Mark said: Looks like a great "Hammer-Mobile" the only thing I'd suggest adding is rocker skids, that way it'll stay looking good! 👍 I bought this from dirt bound off road before they went out of business but I haven’t had time to put it on yet
