Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 Nope Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 i talked to dad about this (hes machanic king around our place) and he says it sounds like your thermostat is either the wrong one or in backwards. or it may have air in the system Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 There is air for sure. Thermostat is a 195 degree and it can't go in the otherway the housing doesnt fit Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 okay then i just read that you should park it on a hill and loosen the sending unit and that will bleed the air out Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 Yes I know i need to do that but it still heated up last time with air in the system Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 it will always heat up eventually another idea to get the air out is o run it with the rad cao off when its uo to temp Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 really so after it warms up just take off cap and let it run for a little bit? Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 just fire it up with the cap off and drive around untill it gets to opoerating temp then put the cap on and see if it helps it should get the air out Link to comment Share on other sites More sharing options...
Automan2164 Posted December 16, 2009 Share Posted December 16, 2009 You guys are forgetting this is the CLOSED system!!!! Jake, do i need to come over there and beat you with the temp sender? Â In this system, it won't burp like an open. Leaving the cap off does no real good. You HAVE TO park it facing down hill while cold, pull the rear sender, and bleed it off. I was assuming you bled it like I told you to after doing the t-stat. It will act like it is UNTIL YOU bleed it. Â Rob L. :fool: Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 oh i told dad it was a cosed system but he said it would work Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 well if you beat me with the sender does that mean you will burp it for me :rotf: :rotf: Link to comment Share on other sites More sharing options...
Automan2164 Posted December 16, 2009 Share Posted December 16, 2009 For some air that will work, but these RENIX 4.0L's are a son-of-a if you don't bleed them properly. Â Rob L. Link to comment Share on other sites More sharing options...
Automan2164 Posted December 16, 2009 Share Posted December 16, 2009 well if you beat me with the sender does that mean you will burp it for me :rotf: :rotf: Â Yep, but I will come a swinging with that sensor if I pull it and there is a HUGE air pocket... :roll: Â Rob L. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 so driving with the pad cap ff won't do much Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 :rotf: Link to comment Share on other sites More sharing options...
Automan2164 Posted December 16, 2009 Share Posted December 16, 2009 so driving with the pad cap ff won't do much  Not on these...  Rob L. :smart: Link to comment Share on other sites More sharing options...
mythreesons Posted December 16, 2009 Share Posted December 16, 2009 well if you beat me with the sender does that mean you will burp it for me :rotf: :rotf:  Yep, but I will come a swinging with that sensor if I pull it and there is a HUGE air pocket... :roll:  Rob L.  Rob, please for the love of MJs everywhere, bleed, burp, beat, whatever you have to do BEFORE he ruins the engine. Please?!?!?!?! Pretty please?!?!?!?!?  While your there, you might take away his tube of RTV. I think he got some in his ears and it's affecting his hearing. :rotfl2:  Scott  JUST KIDDING JAKE!!!!!! You do know that diesels have thermostats as well, don't you? :wavey: Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 :rotf: you can't take my tube of RTV its brand new. :rotf: well i have done my thermostat like 10000 times so i needed it. i learned to use alot less though. Link to comment Share on other sites More sharing options...
mythreesons Posted December 16, 2009 Share Posted December 16, 2009 Glad your using less, you need to go easy on that stuff it'll make your babies come out crooked and bald. :D Â Now, go get some heat in that truck, it can't be real warm up there these days. Â Scott Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 16, 2009 Author Share Posted December 16, 2009 its not to bad like 30's  There was heat after it hit 210 Link to comment Share on other sites More sharing options...
whowey Posted December 16, 2009 Share Posted December 16, 2009 Glad your using less, you need to go easy on that stuff it'll make your babies come out crooked and bald. :D  Now, go get some heat in that truck, it can't be real warm up there these days.  Scott   That's only the silver stuff...... :yes: Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 17, 2009 Author Share Posted December 17, 2009 I bled the system finally. So ill see how it goes now Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 17, 2009 Share Posted December 17, 2009 finally :thumbsup: took ya long enuf but your doin more than i can now . its dangerously cold out side.getting to - 30 windchill ill pass on frostbite :eek: Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 17, 2009 Author Share Posted December 17, 2009 Lol. I hate bleeding the system but it feels like the sun is inside when heat is going. And it sits at 210 Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 18, 2009 Share Posted December 18, 2009 good job man Link to comment Share on other sites More sharing options...
