pilotblake Posted October 30, 2009 Share Posted October 30, 2009 Is there somewhere online that sells the alignment shoe deal that fits in the lower control arm pocket and fixes the one side of the control arm in place. It has the two bolts that bolt to the back of the control arm pocket. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted October 30, 2009 Share Posted October 30, 2009 Snag a handfull out of the JY. :yes: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 31, 2009 Share Posted October 31, 2009 You talking these?? I replaced mine with brandy new factory units when the RE DB's where installed.... CW Link to comment Share on other sites More sharing options...
pilotblake Posted October 31, 2009 Author Share Posted October 31, 2009 You talking these?? I replaced mine with brandy new factory units when the RE DB's where installed.... CW Them be the ones. Did you get them for a jeep dealership? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 31, 2009 Share Posted October 31, 2009 Surenough did!! :D IIRC you need to order the nuts seperately!! CW Link to comment Share on other sites More sharing options...
pilotblake Posted October 31, 2009 Author Share Posted October 31, 2009 Do you remember what the dealership looked then up as. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 31, 2009 Share Posted October 31, 2009 IIRC LCA caster adjustment. I also seem to remember they where had to find if looking for a MJ. Look for it for a XJ. (We know there is no difference.) I THINK I have the set form one of the XJ's I chopped that are useable. LMK and I'll look. CW Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 31, 2009 Share Posted October 31, 2009 LCA CLEVIS, p/n 5200 0532 LCA CLEVIS NUT, p/n 1150 2811 SHIM, .95mm, p/n 5200 0234 SHIM, 4.00mm, p/n 5200 3976 Link to comment Share on other sites More sharing options...
pilotblake Posted October 31, 2009 Author Share Posted October 31, 2009 :thumbsup: :yes: Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 1, 2009 Share Posted November 1, 2009 I think it might be mo-betta to go with some WJ LCA's instead of rebuilding your stock LCA's? Uses the same shims. Especially w. the tires you are running. :cheers: Link to comment Share on other sites More sharing options...
robfg67 Posted November 1, 2009 Share Posted November 1, 2009 Slightly off topic... I plan on swapping out my 20 year old lower control arms with the beefier WJ ones. Do I need to use a shoe or shims? Can't I just swp them out? My front end is completly stock. Yes, I'm aware I'll need to trim the arms to fit. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 1, 2009 Share Posted November 1, 2009 Slightly off topic... I plan on swapping out my 20 year old lower control arms with the beefier WJ ones. Do I need to use a shoe or shims? Can't I just swp them out? My front end is completly stock. Yes, I'm aware I'll need to trim the arms to fit. The WJ arms have the same clevis bracket as the stock LCAs and use the same shims. I had to add shims to correct caster when I did my lift, but since you are staying the same you should be the okay reusing the shims as you removed them. The WJ LCAs are the same length as the old LCAs. Link to comment Share on other sites More sharing options...
aemsee Posted November 1, 2009 Share Posted November 1, 2009 You talking these?? I replaced mine with brandy new factory units when the RE DB's where installed.... CW why does the new one look so much longer than the old one? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 1, 2009 Share Posted November 1, 2009 Must just be the pic.. but it sure looks different don't it??? I'm pretty sure that they where identical.... CW Link to comment Share on other sites More sharing options...
pilotblake Posted November 3, 2009 Author Share Posted November 3, 2009 You talking these?? I replaced mine with brandy new factory units when the RE DB's where installed.... CW why does the new one look so much longer than the old one? Checked at the stealership today to see what the going rate for the alignment shoes was expecting the $20-40 range.........................................NOPE.........$60 :mad: and they could have it for me in 4 days!!! :rant: Looks like I will be making a trip to the JY. For what it is I will make my own before i get taken for that..........at least kiss me on the neck first. :headpop: Link to comment Share on other sites More sharing options...
