vac canister
Some of the older Renix cannisters had two ports w. a built-in check valve; my 91 had the football cannister w. one port and w/o a check valve. Simple answer - replace/relocate w. a similar reservoir to what you have. But unless you have devices besides the normal HVAC controls, like cruise or other devices that need more vacuum, any single port tank will work just fine as long as there is a check valve either inline or built-in the tank.
well i guess i need more explanation of how it works. i was hopping to be able to replace it with something that wasnt a car part and have something different. i could get another oe unit but I'm tryin to be cool. lost it a few days ago and aside from the idle being a little off it hasnt caused me much grief .
