Pics of the 'manche ... before and after!
Well i figured i'd post some pics so you can see what i have been asking all the questions about!! thanks for all the help, still not done, still have to do the trans/case swap to make it 4wd for real!
W
:Canadaflag:
Before:
After:
Thanks..... looked for like 2 years and finally settled on a 91 2wd 4.0 aw4.
4" superlift coils
skyjacker LCA's
skyjacker nitro shocks
skyjacker steering damper
Rubicon express adjustable track bar
sway bar disco's
rear springs re-arched w/ AAL (a little stiff)
Moab wheels/245-75-16 MTR's
donor parts from 94 XJ:
HP D30
AW4
NP231
bucket seats
steering column
console
gauge cluster
trying to find time to do the trans/case swap and have the rear shaft fabbed up. work and life getting in the way again!
thanks for looking!
W
:Canadaflag:
Mine fit just fine. They only rubbed a little bit on the plastic when I turned. I changed to the upgraded front clip and no more rubbing.
I won't be doing any offroading until I get her lifted, they will definitely rub. :D
