88elimnator Posted September 16, 2009 Share Posted September 16, 2009 I was wondering if anyone knows how to fix the oil leak I've already changed the rear main seal and thats where it looks like its coming from and I notice alot of jeeps leak. Link to comment Share on other sites More sharing options...
Eagle Posted September 16, 2009 Share Posted September 16, 2009 It isn't unusual to mess up a rear main seal the first time and have to do it over. Other candidates are the valve cover, and the O-ring where the oil filter adapter mounts to the block. Link to comment Share on other sites More sharing options...
Akula69 Posted September 16, 2009 Share Posted September 16, 2009 Can you give us a little more information? What I mean is, you may have replaced the main seal but there are a lot of variables here. For example: Did you possibly put part of it in backwards? Is your oil pressure high (because of advanced miles on your engine or the breather line is plugged) and the pressure has caused the new rear main to fail? Could you possibly have nicked the crank when you replaced the top part of the seal? Did you used a new 1 piece oil pan seal when you had the pan down for the seal replacement, or did you remove the transmission and use a one piece seal? Are you sure the oil is actually still leaking from the RMS? Sometimes the valve cover can leak at the back and it will run down the block and just look like the RMS is leaking. Could the 'O' rings on the oil filter adapter be worn and leaking, and running down the block? Please let us know a little more and we can narrow it down! :D Edit: dayem Eagle you're quick on the trigger! Link to comment Share on other sites More sharing options...
jpdocdave Posted September 16, 2009 Share Posted September 16, 2009 It isn't unusual to mess up a rear main seal the first time and have to do it over. Other candidates are the valve cover, and the O-ring where the oil filter adapter mounts to the block. x2 on all that. Link to comment Share on other sites More sharing options...
88elimnator Posted September 16, 2009 Author Share Posted September 16, 2009 all that is possible except for knicking the crank I"ll have to check the other stuff. thanks. Link to comment Share on other sites More sharing options...
chunks6067 Posted September 16, 2009 Share Posted September 16, 2009 o ring from the oil filter adapter, almost changed my rear main because i thought that is where it was coming from. I had to degrease the bottom of the engine about 3 times to pin point the leak Link to comment Share on other sites More sharing options...
