8.8 axle help
ok i bought an 8.8 for 75 bucks at the jy, not too bad of a deal. but i have a few questions!
-where can i get the driveshaft flange needed to bolt up the shaft?
-what would you do for spring perches? I'm going soa
-i have calipers and thats about it. will the local auto store have the bolts to hook them up?
-any tips advice things i will forget? help me!
-i have calipers and that's about it. will the local auto store have the bolts to hook them up?
Unsure where to get the flange sans the dealer or another pick-n-pull. (PM me, I have at least one extra) You also need the bolts for it, yes they are special made for this application.
I recommend MOPAR perches, good stout and CHEAP!! (I also have an extra set of these)
I welded up my own hose mounts and used both right side hoses for convenience mounting. then bend up some lines and make some adaptors for the emergency brakes.
CW
