veritas4156 Posted August 26, 2009 Share Posted August 26, 2009 Alright, so I saw this down in the junkyard the other day. There was a switch on a comanche to the right of the steering wheel that had a picture of a transmission, and above it said POWER, below it said COMFORT. What exactly does that do? Link to comment Share on other sites More sharing options...
Geonovast Posted August 26, 2009 Share Posted August 26, 2009 Controls the shift points of the transmission. Shifts at lower RPMs in comfort mode. Comfort is essentially useless, if you ever find yourself with one, just leave it in Power mode. Comfort doesn't save you any gas, trans doesn't like it, and it'll just piss off the people behind you. Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 26, 2009 Share Posted August 26, 2009 Controls the shift points of the transmission. Shifts at lower RPMs in comfort mode. Comfort is essentially useless, if you ever find yourself with one, just leave it in Power mode. Comfort doesn't save you any gas, trans doesn't like it, and it'll just piss off the people behind you. man, i beg to differ! i like my shift-points low, thats how you get gas mileage.. i can't STAND riding in a later cherokee, the darned things don't shift til like 2500 rpm even with minimal throttle input. the 90 my brother owned shifted like butter in comfort mode and usually stayed there, it was the nicest shifting auto-4.0 i've ever been in. Link to comment Share on other sites More sharing options...
Automan2164 Posted August 26, 2009 Share Posted August 26, 2009 :agree: A smooth, low-shift will help the fuel mileage. It think its mostly up to the driver. I chose to leave it in comfort on my '91. Rob L. Link to comment Share on other sites More sharing options...
Geonovast Posted August 26, 2009 Share Posted August 26, 2009 My 88 4.0 4x4 XJ is getting 26 mpg and it's always in power. Link to comment Share on other sites More sharing options...
veritas4156 Posted August 26, 2009 Author Share Posted August 26, 2009 Thats pretty cool. Wish mine had that. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 26, 2009 Share Posted August 26, 2009 The AW4 POWER/COMFORT switch was dumped in 1992 (although there may be some holdovers :D ). My 91 still has it. I've done several tankfuls in both positions and the POWER position netted a solid 1-2 improvement in MPG, as well as crisper shifting and less searching for 3rd/OD gears at the 2000 RPM range when going uphill. After 1992 the switch was dumped and the POWER position was hardwired into the harness. Link to comment Share on other sites More sharing options...
Lenard Posted August 26, 2009 Share Posted August 26, 2009 i like to leave mine in the power mode, cause when its in the comfort position it shifts to soon and dogs real bad, especially OD Link to comment Share on other sites More sharing options...
mvusse Posted August 26, 2009 Share Posted August 26, 2009 The Renix engines like low rpms and can get excellent mileage that way. On stock tires I used to get 24mpg going 60 down the highway. HO engines like to rev higher. My 94 XJ gets better mileage at 75 than it does at 60. So for a Renix 4.0, the switch makes sense. For a HO, it's useless. Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 26, 2009 Share Posted August 26, 2009 The Renix engines like low rpms and can get excellent mileage that way. On stock tires I used to get 24mpg going 60 down the highway. HO engines like to rev higher. My 94 XJ gets better mileage at 75 than it does at 60. So for a Renix 4.0, the switch makes sense. For a HO, it's useless. i'll buy that, sounds plausible. Link to comment Share on other sites More sharing options...
pilotblake Posted August 27, 2009 Share Posted August 27, 2009 :agree: I have the switch on my 89 wagoneer, it got so hot one day I thought it was going to catch fire, now I am not sure what mode it is in :dunno: . Link to comment Share on other sites More sharing options...
