88swampedmj Posted August 28, 2006 Posted August 28, 2006 hey guys iam pretty sure i have the crappy peugot tranny... i have a 88 4.0 5spd manche...and the tranny won't go into 4th.. are the trannys out of tj's a bolt up swap?
Bounty Hunter Posted August 28, 2006 Posted August 28, 2006 All '88 5spds would be the Peugeot BA10/5, they didn't use the AX15 until mid-year '89. The AX15 from a YJ or TJ will bolt in, but you'll likely need to change your clutch master cylinder and transfer case input shaft. The transfer case in Wranglers are clocked higher than in the MJ, so you may need to clearance your tub above the TC, or redrill the mounting flange in the back of the tranny.
Pete M Posted August 28, 2006 Posted August 28, 2006 As hunter said, yes and no. An AX-15 from a TJ/YJ will bolt to the engine, but there are some differences in the back half of the transmission. I have a TJ trans in mine and had to create the transfercase shifter bracket side that bolts to the trans. Plus the tranny mount is different and the TJ/YJ trans will clock or rotate the t-case up a bit. It mean better ground clearance, but can interfere with the floor of the truck depending on how you work out the tranny mount and xcrossmember. Then there's the issue with amost all AX-15s, spline count. Early AX-15s may have the 21 spline shaft to match your t-case, but for sure 91+ will have a 23 spline. 94.5+ will have the external slave. I simply joined my current master line to the new slave line using a $2 compression fitting from the hardware store. Oh, and the Peugeot does NOT share bellhousing with the AX-15, so you'll need to get that with the trans. Some good info here if you haven't read it already: http://www.jeeptech.com/convtrans/ax15swap.html
87manche Posted August 28, 2006 Posted August 28, 2006 all ax-15s were 23 spline. The major differences were in the output shaft length. early ax-15's were short output, later were long, I believe the change happened somewhere about the same time as the external slave deal.
Pete M Posted August 28, 2006 Posted August 28, 2006 I thought it was AX-5s that had the short and long issue. I don't remember hearing that about the AX-15. :hmm:
87manche Posted August 28, 2006 Posted August 28, 2006 http://www.novak-adapt.com/knowledge/np231.htm at the bottom on the right, nifty little chart for the 231's input gears.[/code]
Pete M Posted August 28, 2006 Posted August 28, 2006 The following chart shows how to determine which input gear you might have by transmission. It is always recommended to verify first hand if possible. Good ol' Jeep. Always necessitating a clause or two. :D
87manche Posted August 28, 2006 Posted August 28, 2006 yep. never know what ya got till you take it apart.
88swampedmj Posted September 4, 2006 Author Posted September 4, 2006 is my best be just to find a good tranny out of another mj?
87manche Posted September 4, 2006 Posted September 4, 2006 don't forget thta a cherokee trans will bolt right up. Lots more of those than MJs. It would be easier to get an MJ XJ trans, it's a direct replacement.
88swampedmj Posted September 5, 2006 Author Posted September 5, 2006 would my cherokees 5sp tranny work if i change the bellhousing? its a 86 2.8 v6 cherokee
88swampedmj Posted September 7, 2006 Author Posted September 7, 2006 so would it work? the inline 6 is a 6cyl and the v6 is a 6cyl so if i just take the tranny only...and put it to my comanches bellhousing would it work?
Pete M Posted September 7, 2006 Posted September 7, 2006 The V6 and 4 cylinder engines share manual transmissions. The 4.0L uses different manual transmissions. Essentially they are not interchangeable. It is technically possible to use the bellhousing from a Dakota to adapt the AX-15 from a 4.0L to the 2.5L engine, but it's not exactly a straightforward swap.
Bonkers Posted September 7, 2006 Posted September 7, 2006 all ax-15s were 23 spline. Are you sure? I ripped an Ax15 out of an 89 Chero that was a direct bolt onto my 88 - that wouldn't have been possible if it were a 23-spline.
Pete M Posted September 7, 2006 Posted September 7, 2006 My 90 MJ has a 23 spline. That's all I know for sure. :hmm:
88swampedmj Posted September 8, 2006 Author Posted September 8, 2006 so my v6 5spd tranny outta my cherokee is a no go...? i was pretty sure if i just gut the tranny out of it and use the bellhousing out of my manche it should work, iam sure its a ba10 in the cherokee so if i just use my comanches bellhousing it should work right? i just wanna make sure bc i don't have too much money to throw around and this tranny is free from my cherokee
Pete M Posted September 8, 2006 Posted September 8, 2006 If you think you have a BA-10 in your 86 Cherokee, I'd love to see a picture. :brows:
ejndssn Posted September 10, 2006 Posted September 10, 2006 the ba-10 came with the 87-89 4.0l which had a 21 spline and the ax-15 had 23 spline the 2.5l(4) & 2.8l(6) shared the ax-5 since the had bout the same pwr rating :cheers:
