maddzz1 Posted July 27, 2009 Posted July 27, 2009 I am looking for the thread about removing the height sensing valve. The one where someone drew some diagrams asking which was the correct way to do it.
maddzz1 Posted July 28, 2009 Author Posted July 28, 2009 Thanks 64, but thats not it. The one I'm looking for someone used illustrator or paint to draw the axles and the brake lines. For some reason I can't find it.
64 Cheyenne Posted July 28, 2009 Posted July 28, 2009 Well if you find it, please post it. As it is now, that is the info I'm going to be using to do the same thing. If you do find, it I'd like to see it, as I would like to learn as much about it as I can before I do it to my truck.
maddzz1 Posted July 28, 2009 Author Posted July 28, 2009 No Pete, Someone actually drew the front and rear axle using something like paint or illustrator and drew in the brake lines showing which port to plug and stuff. There was alot of info in the thread
maddzz1 Posted July 28, 2009 Author Posted July 28, 2009 Found It: viewtopic.php?t=4968&highlight=prop+valve
Wildman Posted July 30, 2009 Posted July 30, 2009 :thumbsup: That's the one your brought up in another topic, that's the picture(s) :D I looked again last night, but after a half hour+, I only got back to 11/07 :ack: Nice find :D
maddzz1 Posted July 30, 2009 Author Posted July 30, 2009 :thumbsup: That's the one your brought up in another topic, that's the picture(s) :D I looked again last night, but after a half hour+, I only got back to 11/07 :ack: Nice find :D Yeah, Bob. Took a while but I found it. Bookmarked it this time.
HOrnbrod Posted July 30, 2009 Posted July 30, 2009 Yeah, Bob. Took a while but I found it. Bookmarked it this time. Good job Jim. I could not find this either, and am also bookmarking this link if and when the time comes to ditch my rear prop valve. :cheers:
Wildman Posted July 31, 2009 Posted July 31, 2009 Don, I thought you wanted to keep the rear proportioning valve :hmm: I know it just don't fit in, but you can send it to this company and have the thing "fit" in with the rest of your MJ :D
HOrnbrod Posted July 31, 2009 Posted July 31, 2009 Don, I thought you wanted to keep the rear proportioning valve :hmm: I know it just don't fit in, but you can send it to this company and have the thing "fit" in with the rest of your MJ :D I am keeping the rear prop valve, but who knows how long it's going to last? So far so good though. I'm getting ready to mod it though by adding an adjustment sleeve on the new rod I put on, like a tie rod sleeve so I can zero it in. Having a hard time finding a 1/4"x28 LH die though. You don't happen to have one I could "borrow" do ya Bob? :cheers: And thanks for the link Bob. I have heard of these folks and they do super work.
Wildman Posted July 31, 2009 Posted July 31, 2009 No, I don't have any left handed taps or dies........got some left handed drill bits ;) I wonder if you need to use left handed drill bits for the left handed taps :hmm: The easy fix........would be to cut what you have in half, and weld in the "extension" to what OA length you need :D (Or shorten) I have one good RPV that I bought from a member here on the shelf, If your decides to puke out, let me know.......or do you want to hang on to it???? I don't think I'll ever use it. It's not plated thought :(
