smithe1811 Posted July 24, 2009 Share Posted July 24, 2009 its sucking air and when i block it, my rpm's drop a bit Image Not Found Link to comment Share on other sites More sharing options...
WBKrazy Posted July 24, 2009 Share Posted July 24, 2009 not sure but i think that's the ccv hose.... it's goes into the stock airbox Link to comment Share on other sites More sharing options...
dakal Posted July 24, 2009 Share Posted July 24, 2009 just plug it :yes: Link to comment Share on other sites More sharing options...
Eagle Posted July 24, 2009 Share Posted July 24, 2009 What are we looking at? WBBKrazy mentioned the stock air box, but it looks to me like this vehicle doesn't have a stock air box. Is there an arrow in that photo that I'm not seeing? Link to comment Share on other sites More sharing options...
smithe1811 Posted July 24, 2009 Author Share Posted July 24, 2009 its the little hose that has the red lines around it. it wasnt hooked up to the stock aorbox when i got the truck but it could have been pulled out by the PO. Link to comment Share on other sites More sharing options...
Lemmon714 Posted July 25, 2009 Share Posted July 25, 2009 The disconnected hose goes to the stock airbox. I think it is the heat control on the inlet air. I agree with Dakal- I would plug it. It's causing you a vacuum leak. (It may also be how your comanche gets it daily dose of yuengling black and tan.) Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted July 25, 2009 Share Posted July 25, 2009 Over to the right of your line with the red outline there is a 90 degree fitting coming out of a black box, about 2-3 inches over from the end of your line, might it go there? I noticed another vacuum line coming from that box. :dunno: Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 25, 2009 Share Posted July 25, 2009 That line does go to the bi-metal temp sensor at the back of the stock air box. The line directly behind it goes to the EGR solenoid on the fender (right of your picture) which you can see is connected. Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted August 3, 2009 Share Posted August 3, 2009 Yes i had the same prob when i put a snorkel on i just put it in the one with the 90 angle piece ;) Link to comment Share on other sites More sharing options...
jbhill Posted August 3, 2009 Share Posted August 3, 2009 looks like it was supposed to go in that sensor by your filter. Link to comment Share on other sites More sharing options...
