Myron Posted July 23, 2009 Posted July 23, 2009 Where is the fuel pump ballast resistor? I think that is reason why my fuel pump is on a switch. The wire runs from the battery to an orange wire inside the cab, behind the seat. Thanks for your help.
MiNi Beast Posted July 23, 2009 Posted July 23, 2009 suppose to be on the inner fender wall on the drivers side under the hood. :yes:
HOrnbrod Posted July 23, 2009 Posted July 23, 2009 I think that is reason why my fuel pump is on a switch. The wire runs from the battery to an orange wire inside the cab, behind the seat. Unless someone wired in a primitive anti-theft device. :brows:
Myron Posted August 11, 2009 Author Posted August 11, 2009 I think I have a problem. Mine looks like this. Image Not Found
64 Cheyenne Posted August 11, 2009 Posted August 11, 2009 Myron,I think your looking too close to the firewall, the resistor is supposed to mount closer to the to the L/front corner of the engine compartment. See the hood pop-up spring in Pete's pic?
Myron Posted August 12, 2009 Author Posted August 12, 2009 The overflow bottle runs the all the way down. I took it off and there is nothing behind it. Is the ballast resistor only on the 6cyl? Or maybe in a different place on the 2.5?
64 Cheyenne Posted August 12, 2009 Posted August 12, 2009 Not sure,think you might be right.Another reason it could be on a switch is that the relay could have gone bad and the PO didn.t know how to fix it.
Myron Posted August 13, 2009 Author Posted August 13, 2009 I take it that the 2.5L has no fuel pump ballast resistor?
Mongo Posted August 13, 2009 Posted August 13, 2009 I did a check in my electrical troubleshooting manual for the 88 comanche. It only shows the ballast resistor on the 4.0 engine fuel control schematic only.
