dunl Posted July 10, 2009 Share Posted July 10, 2009 If I wanted to mock up an engine swap to an AX-15, do I need one from a Comanche, or is there any difference in input shafts and stuff for one from a Cherokee or YJ? Thanks. Link to comment Share on other sites More sharing options...
Geonovast Posted July 10, 2009 Share Posted July 10, 2009 Nope, they're all the same in that regard. XJ/MJ AX-15s are identical, and the YJ/TJ units clock the T-case a few degrees differently, but the fronts are all the same. Link to comment Share on other sites More sharing options...
dunl Posted July 10, 2009 Author Share Posted July 10, 2009 Nope, they're all the same in that regard. XJ/MJ AX-15s are identical, and the YJ/TJ units clock the T-case a few degrees differently, but the fronts are all the same. Shaw-WEET! Thanks dude. :) Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2009 Share Posted July 10, 2009 My brain is telling me that the early years had a different diameter input shaft (took a different pilot bearing). :hmm: Link to comment Share on other sites More sharing options...
jeepaholic Posted July 10, 2009 Share Posted July 10, 2009 pete is right..different pilot bearing.. Link to comment Share on other sites More sharing options...
BlueXJ Posted July 10, 2009 Share Posted July 10, 2009 The research that I have done says that the pilot shaft size changed with the end of the Renix years on XJs which I assume is the same time for MJs. Link to comment Share on other sites More sharing options...
dunl Posted July 10, 2009 Author Share Posted July 10, 2009 So is my 1990 fine, or does it have the different shaft/bearing? Link to comment Share on other sites More sharing options...
dunl Posted July 11, 2009 Author Share Posted July 11, 2009 So if I have a 1990, the info I can find is that the Renix controls were switched starting in 1991. So I would have the different shaft/ bearing? The bearing/ shaft diameter, not so big a deal....the shaft...does the length differ? Link to comment Share on other sites More sharing options...
Geonovast Posted July 11, 2009 Share Posted July 11, 2009 Shaft length is the same, but the diameter at the tip for the bearing was changed. If you're putting a newer AX-15 on a renix motor, you'll need a 74 CJ 304 pilot bushing. Link to comment Share on other sites More sharing options...
dunl Posted July 11, 2009 Author Share Posted July 11, 2009 Thanks, I'm thinking of using the AX-15 to swap to a diesel. And to mock it up, long as the shaft is the right length, I can do that. But to mate the actual AX-15 I have, I'll need to find another bearing that fits this diameter, or just swap AX-15's as well when I pull the engine (as I know which bearing I need for the later AX-15's). Would my 90 AX-15 likely be the same as an 87 YJ, or possibly different (barring possible swaps). Link to comment Share on other sites More sharing options...
Eagle Posted July 11, 2009 Share Posted July 11, 2009 Would my 90 AX-15 likely be the same as an 87 YJ, or possibly different (barring possible swaps). An 87 XJ or MJ would have a Peugeot BA 10/5 transmission. I'm not certain what tranny the YJ used in that year. For the XJ and MJ, the change from the BA 10/5 to the AX-15 was made in the middle of the 1989 production year. Link to comment Share on other sites More sharing options...
Pete M Posted July 11, 2009 Share Posted July 11, 2009 As far as I know, the YJs roughly mirrored the MJs with inline 6 manual transmissions year to year (even though the YJs never got the 4.0 renix). Link to comment Share on other sites More sharing options...
dunl Posted July 11, 2009 Author Share Posted July 11, 2009 Hmm, I'll have to check with the guy I am getting info from. His 87 Wrangler now sports a om617 Mercedes motor, mated up to an AX-15. Must have swapped the tranny too. Link to comment Share on other sites More sharing options...
dunl Posted July 12, 2009 Author Share Posted July 12, 2009 PO swapped the tranny, and he's not sure which he has. Link to comment Share on other sites More sharing options...
Pete M Posted July 12, 2009 Share Posted July 12, 2009 AX-15 on the left, Peugeot on the right. Note the line of bolts on the top (and on the bottom) that split the Peugeot into a left and right half. Link to comment Share on other sites More sharing options...
Gr8plainsDriftr Posted July 13, 2009 Share Posted July 13, 2009 would the tail shaft/out put stuff from a ba10/5 work on a 2wd ax-15? reason i ask is because i found a 2wd ax-15, its the only thing hanging me up from finishing my HO swap. i doubt it will work, but maybe someone has tryed it? Link to comment Share on other sites More sharing options...
Geonovast Posted July 13, 2009 Share Posted July 13, 2009 Nope. Link to comment Share on other sites More sharing options...
Gr8plainsDriftr Posted July 13, 2009 Share Posted July 13, 2009 probably not worth it anyway. Anyone want to buy a np249 or a good ba10/5 so i can buy a 4wd ax-15? Link to comment Share on other sites More sharing options...
