HOrnbrod Posted June 10, 2009 Share Posted June 10, 2009 Here's a simple one - even a Caveman can do it. After I developed leaks for the second time with the vacuum lines going through the front bulkhead under the battery to the football vacuum reservoir behind the right front bumper, I decided to junk it and move the reservoir into the engine compartment where it belongs. I picked up a canister from a Porsche 944 that looked like it would work for $2, and located it in front of the blower motor where it fits in there just fine using the existing PDC screws. Plumbing was easy; there's a "T" fitting on the firewall just above it where one line goes to the HVAC controls in the cab and the other goes to the cruise control module then out to the old canister. There is a check valve on the line going to the HVAC, so you want to splice in the new canister after that "T" fitting like the old one is. Although this canister is smaller than the old football, it works just fine. Plenty of vacuum reserve for the HVAC, A/C, and cruise. :cheers: Quote Link to comment Share on other sites More sharing options...
mjeff87 Posted June 10, 2009 Share Posted June 10, 2009 I originally moved mine to the radiator header panel when my MJ was still a 2.5 (there's plently of room there with the 4 banger but not with the 4.0) Then I moved it to where you moved yours Don......then I swapped a dual diapraghm booster in and had to relocate the washer fluid resivoir....it fit perfectly right above the blower motor ;) So I moved the vac blimp to the inside fenderwell where the resivoir used to live at. It's all pieces n' parts, which is what I love about Jeeps. Still thinking about swapping in the late model XJ resivoir that lives inside the fender like you posted, but I don't know how long it would survive with the 35's :D Jeff Quote Link to comment Share on other sites More sharing options...
RLCollins Posted December 16, 2009 Share Posted December 16, 2009 how do you troubleshoot that vacuum football behind the right front bumper? :dunno: Quote Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 30, 2010 Share Posted January 30, 2010 When I got an aftemarket bumper on my XJI moved the "football" up where the coolant pressure bottle used to go because I converted to open cooling. I have it strapped to the firewall. I had to remove the platform where the pressure bottle was. On the MJ I just have a ball (no cruise control). I have converted that to open cooling too. Since the ball is smaller than the football I'll do the same with the ball and be able to put a smaller overflow bottle right next to it, that's todays project. I'll take a picture. Quote Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted February 13, 2010 Share Posted February 13, 2010 Looks clean, nice job! Quote Link to comment Share on other sites More sharing options...
Tex06 Posted April 28, 2017 Share Posted April 28, 2017 When I got an aftemarket bumper on my XJI moved the "football" up where the coolant pressure bottle used to go because I converted to open cooling. I have it strapped to the firewall. I had to remove the platform where the pressure bottle was. On the MJ I just have a ball (no cruise control). I have converted that to open cooling too. Since the ball is smaller than the football I'll do the same with the ball and be able to put a smaller overflow bottle right next to it, that's todays project. I'll take a picture. Sorry to resurrect the dead, but did you ever get a pic? I've got a non-cruise truck and need to do something about mine. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
