Hey guys. Can anyone recommend weather or not i should run puller or pusher fans for this LS1 swap I'm doing? :dunno: I got that custom Alum rad and its only got room for maybe a Dual 10" but nothing taller then that. With it being custom the normal upgrades i have seen guys do WILL NOT WORK !!
Thanks in advance
Push or pull depends upon which side of the radiator you mount the fan on. If you mount it in front of the rad you want a push, if it is behind the rad you need a pull. All depends upon mounting position.
For off road I would suggest a push fan in front of the radiator. That way when you go into deep water the fan blades can't pull themselves into the radiator, but will actually try to pull away. For a street vehicle pull fans might be more efficient.
when you still have cooling issues, you have take little fans and get some hose and run some cold air going into the rad from somewhere thats not hot. like the wheelwell.
Well i went with dual puller's with the idea of stayin mostly on the road with some offroad on the side. Has anyone done both? Add pusher and puller. How well is this going to work if i just over lap the edges of all three fans.
:doh: Sorry i have them already in the truck. But this is what i have to show. don't mind the big metal tube its the power steering cooler from the LS1's donor still not sure if I'm going to use it or not yet.
