64 Cheyenne Posted May 10, 2009 Posted May 10, 2009 I'm converting my 87 MJ 2wd to 4wd. The trans, clutch,and MC assy came out of a 99 XJ. Here was my problem and how I solved it. This is a pic of where the 87 MC mounted. And this is a pic of the configuration of how the 99 MC would mount. The problem is that the 87 mounts at the 12 and 6 O'clock position, and the 99 mounts at the 5 and 11 O'clock position. Another problem is the bolt mounting centers are also different. I thought about just drilling holes at the 5 and 11 as shown by the Xs, and I also trimmed the index on the mount thinking that if I rotated the mount I might be able to gain a more favorable mounting position. I eventually left it in the stock location at the 5 and 11 position. To gain more room, I rerouted the hood release cable threw the grommet to the upper right in this view. Then I cut a 4"x4" piece of 3/16 steel. Cut a 1 1/2" hole in the center, welded 2-3/8" bolts to the backside, on the stock mounting centers. Then I Cut the 99 mount into a round shape, welded it onto my new mounting plate. Hows this for my first weld project with my new HF welder? Better than some guys can't do.... :yes: Although it still looks like DOO-DOO. The reason that I didn't just drill holes at the 5 and 11 positions is this, first there might have been clearance issues on the backside and second and most important part is that if I did this then structurally I would be putting the force/stress of using the clutch on the sheetmetal of the firewall alone. The force needs to be on this bracket. If I was to do anything different I would have taken the time to remove this bracket/brace from the backside of the firewall,before I did any fabricating. There is only one bolt holding it on when the MC is removed. Image Not Found Image Not Found I would have removed this bracket for 2 reasons. One, the stud on the bottom has to be removed (I tried to remove it the hard way, cutting drilling it from the engine side) Do yourself a favor and take it off from the backside of the firewall, way easier! And second it can be used as a jig in setting up your mounting bracket to insure you have the correct bolt centers. Well all that is left is to take finished pictures of the install, but first I have to get a plug for where the hood release cable originally ran. Then I can put a bead of sealant behind it and bolt it up!
jtdesigns Posted May 10, 2009 Posted May 10, 2009 Nice job ! :thumbsup: That HF welder didnt do too bad a job. I look at it like this... I don't have to be able to weld pretty, just be able to grind it pretty, and make sure the welds have good penetrations...
64 Cheyenne Posted May 11, 2009 Author Posted May 11, 2009 And the finished product Now I'm moving onto installing this. AX-15 and 231 TC
Codycobra84 Posted May 29, 2009 Posted May 29, 2009 Nice work, but not tryin to knock what you did or anything, but why couldn't you just get the clutch master cylinder from like a mid '90s XJ with a 5spd? When I did my AX-15 swap I picked up one at the j/y and it just bolted in
64 Cheyenne Posted June 4, 2009 Author Posted June 4, 2009 I would have, but the JY that I bought the AX-15 from is halfway across the state and Montana is a big state. I bought the trans and accessories sight unseen (delivered by truck) from info I got from the Car-Part.com web site. The JY told me the parts were off of a 99 Cherokee (and according to the bill of lading), Then I never got around to installing these parts till lately. Also since, the MC had a different configuration, I assumed.... it was because of the different years. Last of all, I didnt have any idea that I had a TJ MC, as I had no reason to think or research for otherwise. Oh Well.....Done deal now.
DodgeFan01 Posted June 8, 2009 Posted June 8, 2009 Just out of curiosity, why didn't you just drill two new holes in the firewall like you were thinking with marking the X's? :dunno:
64 Cheyenne Posted June 9, 2009 Author Posted June 9, 2009 That wouldn't have been structurally correct, as the support for the MC comes from the mounting bracket behind the firewall.If I would have drilled where the X's were the support for the MC would have relied solely on the firewall sheet metal, not really a very good idea. You can see in my pics what I am talking about.
DodgeFan01 Posted June 9, 2009 Posted June 9, 2009 Ok, I got you, that definitely makes sense. :thumbsup: I definitely would not want to rely solely on the strength of the firewall. That is a great fix to the problem what you did making your own MC mounting plate! Jeep On!
mbred0609 Posted October 30 Posted October 30 I know this is an old thread, but since i just came across it I wanted to add some information. The people saying that is a tj master and not an xj master are both right and wrong. It is indeed a 99 (probably) xj master OR a tj master. These pictures are of a 99 xj I'm using as a donor , a 2001 tj , and my 99 2 door . Either way for those saying that any master will be a direct bolt on are wrong (not particularly in this thread but one associated with it). I do not have any HO masters around to verify if they are a direct bolt in or not. Again sorry for reviving an old post but I felt the information may be helpful to someone in the future. Lastly thanks for the pics on the mod I will probably do something similar.
