maddzz1 Posted May 4, 2009 Share Posted May 4, 2009 do the two bolts at the top of the bell housing with the star shaped heads need to come out to drop the tranny? what tool do i need? How many bolts around the bell housing. Try to drop it but it won't budge. Link to comment Share on other sites More sharing options...
Pete M Posted May 4, 2009 Share Posted May 4, 2009 If those 2 bolts are the same as the manual trannys, then yes they need to come out, and they are require an E-10 (at least I think that's the right number) reverse torx socket bit. Link to comment Share on other sites More sharing options...
Wildman Posted May 5, 2009 Share Posted May 5, 2009 :agree: There called "external" torx {Star} bolts (screws) and you need a set like This Also, the one on the right side hold the dip stick/filler tube, once you remove that bolt, you can pull the top section of the filler tube out, And if you have not realized yet, the bottom section of the filler tube is welded to the pan :doh: Link to comment Share on other sites More sharing options...
maddzz1 Posted May 5, 2009 Author Share Posted May 5, 2009 thanks, thats what we needed. it was an e12. i will put it in the bolt size thread. then the didstick tube was stopping it, took a minute to figure that out, :fool: Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2009 Share Posted May 5, 2009 Yes, E-12. I knew E-10 just didn't sound right. :doh: Link to comment Share on other sites More sharing options...
Geonovast Posted May 5, 2009 Share Posted May 5, 2009 Once you get the bolts out, go buy replacement regular hex head bolts. Once you have the fun experience of getting them out, you don't want the even funner experience of getting them back in. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 6, 2009 Author Share Posted May 6, 2009 Once you get the bolts out, go buy replacement regular hex head bolts. Once you have the fun experience of getting them out, you don't want the even funner experience of getting them back in. Getting them out wasnt too bad, we cut the whole tranny tunnel out (it was the donor). Good idea to replace them tho. Link to comment Share on other sites More sharing options...
Casper2000 Posted May 6, 2009 Share Posted May 6, 2009 Wildman. You have a Manche that servived a new york salt season. WOW :bowdown: I want to see this thing. Link to comment Share on other sites More sharing options...
