MJ Nose Job???
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
This is a WJ steering box for those who haven't seen one.
Image Not Found
Tell me what you think.
:cheers:
uhh...that's sick!
Those are just my "Inspiration Pictures". I will also have a cowl induction hood scoop on my MJ along with the extended cab and custom bed that will be dovetailed ending at the rear shackles. It shoud also have 350-400HP. :brows:
I have a long way to go to finish but mine will look as good if not better. My fenders are cut way more with the goal of 37" tires good uptravel and a low COG. ;)
I have no clue why a Benz was used to flex on. :shake: I would never do that.
I just saw that MJ on another site yesterday and thought about how great of a job was done! I think it was GLXJ? Or NAXJA?
EDIT: But please put headlights that fit into that header panel rather than the Hellas it just doesn't look right without it.
I will be keeping my square headlights and will add new turnsignals to the custom bumper or grille. It will be narrowing it 2" less then the MJ pictured.
Like I stated in my original post it will have square headlights. ;)
:cheers:
