Timmaay Posted April 3, 2009 Share Posted April 3, 2009 Need ASAP Waterpump bolt torque? Link to comment Share on other sites More sharing options...
mfpdm Posted April 3, 2009 Share Posted April 3, 2009 My Mitchell repair cd has 13 ft lbs for the water pump bolts. :cheers: Link to comment Share on other sites More sharing options...
kar120c Posted April 3, 2009 Share Posted April 3, 2009 lol, was about to post but mfpdm beat me to it. I also have the Mitchell repair system cd which lists the same for 2.5/4.0 engines. :cheers: Link to comment Share on other sites More sharing options...
jtdesigns Posted April 3, 2009 Share Posted April 3, 2009 13 ft lbs from 88 fsm Link to comment Share on other sites More sharing options...
Timmaay Posted April 3, 2009 Author Share Posted April 3, 2009 Sweet, thanks guys. Next question, what is the best way to tighten the waterpump pulley bolts. I can only tighten them as much as I can holding the pulley from spinning by hand. Link to comment Share on other sites More sharing options...
Geonovast Posted April 3, 2009 Share Posted April 3, 2009 Sweet, thanks guys. Next question, what is the best way to tighten the waterpump pulley bolts. I can only tighten them as much as I can holding the pulley from spinning by hand. Put the belt on. Link to comment Share on other sites More sharing options...
Timmaay Posted April 3, 2009 Author Share Posted April 3, 2009 Sweet, thanks guys. Next question, what is the best way to tighten the waterpump pulley bolts. I can only tighten them as much as I can holding the pulley from spinning by hand. Put the belt on. will do thank you Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 3, 2009 Share Posted April 3, 2009 they have torque specs for that? :nuts: next you'll tell me they have torque specs for valve covers and oil pans and transmission pans :ack: Link to comment Share on other sites More sharing options...
Geonovast Posted April 3, 2009 Share Posted April 3, 2009 they have torque specs for that? :nuts: next you'll tell me they have torque specs for valve covers and oil pans and transmission pans :ack: The only thing I have EVER used a torque wrench on was a head. Everything else is gud'ntite. add: Oh, and Main bearing caps. Link to comment Share on other sites More sharing options...
