sinkrun Posted March 25, 2009 Share Posted March 25, 2009 1989 4.0 155,000 motor is realy noisy for about 30-50 seconds when I first start it. The oil light hangs on while this is going on also. Coulpe of people said it sound like rods or bearings. This truck had 300 miles put on it in two years. Could it just need cleaned out or is it on its death bed? Oh I have put about 3000 miles on it in 3 months changed the oil twice and it does help some with the noise and light time. Link to comment Share on other sites More sharing options...
beaterjeep Posted March 25, 2009 Share Posted March 25, 2009 What weight oil are you using? Also synthetic, or dino? Very possible it's lifter tick, and can be 'quited' with a little heavier oil, but that just masks the real problem. Link to comment Share on other sites More sharing options...
sinkrun Posted March 25, 2009 Author Share Posted March 25, 2009 Regular 10w-30 Link to comment Share on other sites More sharing options...
summerinmaine Posted March 25, 2009 Share Posted March 25, 2009 Sounds a bit like the rod knock I've got (only lasts about 5 sec on start-up however). But with 300K on the motor, can't complain. BTW I use 20-50, but it's pretty temperate down here. Link to comment Share on other sites More sharing options...
Eagle Posted March 25, 2009 Share Posted March 25, 2009 IMHO 10W30 was too light for a new engine. I ran my '88 XJ on 10W40 up to about 175,000 miles, then I switched to synthetic. I wanted a light viscosity for cold winter starts, but enough body for highway cruising and wheeling in hot weather. So I've been running Castrol Syntec 5W50. Good stuff. By the way, be sure to use an oil filter with a good anti-drainback valve. I use only Purolator. Do NOT use a Fram oil filter. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted March 25, 2009 Share Posted March 25, 2009 I agree with the Castrol 5w50. Been using it in my Hyundai Accent since I bought it with 36000 on the clock, I now have 147000 on it and it still runs as strong as the day I bought it. Though if you have a rod knock, you may want something heavier on the cold end like a 20w50. That might buy you some time if it really is a rod knock. I am currently using Castrol High milage in my MJ. Owner said he replaced thee engine at about 140000, Clock now shows 341000, so I assume my rebuilt engine has 200000 on it. Afraid to put synth in an engine with such high miles......sorry if I hijacked :doh: Link to comment Share on other sites More sharing options...
bigd44889 Posted March 25, 2009 Share Posted March 25, 2009 ok nobody has told u what is wrong yet just how to mask it the probem is just the motor is wore alot it needs rebilt before it does start knocking when u start it it rattles and knocks till oil presser builds up when the presser builds up it it puts that little bit of presser between everything and quitsmaking noise Link to comment Share on other sites More sharing options...
BLHTAZ Posted March 25, 2009 Share Posted March 25, 2009 I think I would try having the rod & main bearings replaced. At 155K, the engine should still have a lot of life left in it unless it has been abused. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 25, 2009 Share Posted March 25, 2009 ok nobody has told u what is wrong yet just how to mask it the probem is just the motor is wore alot it needs rebilt before it does start knocking when u start it it rattles and knocks till oil presser builds up when the presser builds up it it puts that little bit of presser between everything and quitsmaking noise the ONLY reason a motor gets this way is when someone uses chitty oil filters. Fram, K&N, and ALL OTHER performance filters are junk. as Eagle said, you need one with a superior anti--drain back valve (basically a back-flow-preventer). this keeps oil up in your valves and lifters after you shut it off rather than draining back down like performance filters do. make no mistake, "performance" filters do nothing but destroy your motor. they're no good, and don't have the good qualities of other filters. filters I'd run in my motors WIX Purolator genuine MOPAR that's my list. that is all I'd consider running. on a H.O. 4.0 the only filter I will run is genuine MOPAR it has the most superior filtration and back-flow prevention of all of them. this means no metal on metal contact at startup, and no particles getting where they don't belong. -Pat Link to comment Share on other sites More sharing options...
bigd44889 Posted March 25, 2009 Share Posted March 25, 2009 i agree about what filters to run and thay may have helped cause the problem but changing the filter now won;t fix the probem he has only real fix is rebuild or at least mains anything else is just a bandaid Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 25, 2009 Share Posted March 25, 2009 i agree about what filters to run and thay may have helped cause the problem but changing the filter now won;t fix the probem he has only real fix is rebuild or at least mains anything else is just a bandaid yup. I always suggest, for a motor rebuild, grabbing a motor for cheap that runs, tear it down, reseal, and add any performance parts you wish...then swap, and keep the old one for a spare. if you can't keep the old one as a spare, then sell it for a hundo and get some coin back. to re-iterate my previous post...the reason motors get that way with chitty filters is that people get in and start pounding the motor right away, before the oil has any time to get to the moving parts and lubricate. Link to comment Share on other sites More sharing options...
sinkrun Posted March 25, 2009 Author Share Posted March 25, 2009 Thanks for all the input and ideas I was just thinking about looking for a motor to get ready to build. Or a HO swap or a stroker rebuild if I can swing it. I have a friend that layed off right now who has the know how to do it. Time to start looking for a donor. ANy sugestions or rebuild kits stroker and standard? Link to comment Share on other sites More sharing options...
