thanks for the site
i just ran mine: it said under model:
hinterantrieb comanche 6 foot bed
ok what is hinterantrieb :nuts:
also it was a two wheel drive before being converted
Evidently, hinterantrieb is a German automotive term. But it's not listed in any online German dictionary. :dunno:
-edit - As far as I can tell, hinterantrieb means rear-wheel drive.
Any Jeeps older than about 1990 are likely to produce questionable codes when you run a build sheet -- or just draw a blank.
When Chrysler bought AMC, they didn't expend much effort entering historical build sheet data into their database. Also, many of the codes originally used in the early XJ/MJ years were subsequently recycled by DaimlerChrysler, so you may find yourself with a build sheet listing options that weren't available on ANY vehicle in the year your Jeep was manufactured.
If you have an XJ or MJ that's still fairly original, there was often a build sheet either uder the driver's seat or behind the trim panel in the driver's door.
thanks for decoding the german. i'm glad to know i have rear wheel drive. i'm cc this letter to the factory. :D
You can go HERE and it will break the VIN down better for earlier models. And yes it says FSJ but it is for all Jeeps.
:cheers:
Weren't the late model Cherokee base models designated 'SE'?
I think this is an example of Chrysler code "recycling."
My 94 Cherokee says "Pioneer" on the fenders, but according to the Chrysler VIN decoder and auto parts store computers it's an SE.
