quick question on models
renOnv
Any Jeeps older than about 1990 are likely to produce questionable codes when you run a build sheet -- or just draw a blank.
When Chrysler bought AMC, they didn't expend much effort entering historical build sheet data into their database. Also, many of the codes originally used in the early XJ/MJ years were subsequently recycled by DaimlerChrysler, so you may find yourself with a build sheet listing options that weren't available on ANY vehicle in the year your Jeep was manufactured.
If you have an XJ or MJ that's still fairly original, there was often a build sheet either uder the driver's seat or behind the trim panel in the driver's door.
