bdjr Posted July 26, 2006 Share Posted July 26, 2006 To remove the bed from my manche? 1...2...3...where's the torch? actually 8 for the bed, 3 for the e-brake, 3 tank hooks and 2 exhaust hangers and don't forget to free up the wiring harness. I started the removal of the bed and building of the new frame. more pics to come. any suggestions on inexpensive mods for a 2wd, I made 2 inch spacers in the front. will be swapping the stock coils for coils out of a v8 grand cherokee, should add another inch. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found bill Link to comment Share on other sites More sharing options...
pingpong Posted July 26, 2006 Share Posted July 26, 2006 I say hack the frame behind the cab.. then add dubious amounts of DOM... then add 3/4 ton or 1ton axles.. well heck might as well tell you to build a rig like mine :D Link to comment Share on other sites More sharing options...
bdjr Posted July 26, 2006 Author Share Posted July 26, 2006 if you only new how many times i've looked at your truck :bowdown: . just can't afford to do it :cry: . besides mine is only 2wd though i would love to jack it up. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 26, 2006 Share Posted July 26, 2006 Convert it to 4wd. It can be done cheap enough. But, you see, since you don't have 4wd from the factory, you can do it right! Go get a waggy D44 front and put some leaf springs up there, and a toyota 8" or isuzu 12B rear. Then get a tranny/tcase of your choice. Link to comment Share on other sites More sharing options...
Twisty Posted July 27, 2006 Share Posted July 27, 2006 wow thats one rusty bed!! i gotta do that soon too, and paint the frame with POr15 Link to comment Share on other sites More sharing options...
bdjr Posted July 27, 2006 Author Share Posted July 27, 2006 i just finished p-washing and power brushing the rust and muck off. then put on a couple of under coats on it. looks good now. will send more pics. the new bed frame is welded as well. just finished grinding out the welds (how do you spell that, where's the spell check button 8) ). will post thoses pics in the am. Link to comment Share on other sites More sharing options...
mjeff87 Posted July 27, 2006 Share Posted July 27, 2006 Convert it to 4wd. It can be done cheap enough. X2 :cheers: Jeff p.s. let me know how much lift the ZJ coils give you. I've got a set to toss into mine, and am hoping between them and a 1-1.5" spacer I can get 3" in the front. Mine is (was) a 2WD 2.5L also Link to comment Share on other sites More sharing options...
bdjr Posted July 27, 2006 Author Share Posted July 27, 2006 will do. rumor has it ishould give about 1-1.5" Link to comment Share on other sites More sharing options...
jbhill Posted July 27, 2006 Share Posted July 27, 2006 yea when i went to take the bed off of mine, it took me a while to just find all the dam bolts! Link to comment Share on other sites More sharing options...
