Nope.
The 5spd behind a 4 banger wouldn't last anyhow behind the 4.0
Not unless it has been swapped with an AX-15. Even then the bellhousing would still need to be changed for one from behind a 4.0
:cheers:
thanks. i was afraid that the swap would be a little bit tough. although i do have a 5 spd that came out of a two wheel drive mj. although it's missing second gear....
