XJ lift shackels on a MJ
Instead of a lift shackle, you should get the 7.5" TnT y-link lift kit, but I wouldnt run stock axles with it, so you'll have to give SOLID a call and order a set of 44's, and with your new axles you will definitly need a nice new set of 35's, and get beadlocks for them, oh yeah you still need shocks and some other little things, but that will level out your truck real nice.
BTW my truck is a 2.5 2wd, I am looking for a little more clearance between the 235/75/15 tires and the factory fender flares. I have installed spring spacers in front just wana bring the rear up level,2" should do it. This truck won't see any offroad duty except to the brush dump. Thanks Guys
Find some decent condition 4wd MJ leaf packs. They should be good for an inch or so over 2wd leaf packs. If you need a bit more, take the main leaf from your old packs, cut the eyes off, and add it in as an add-a-leaf below your new main. :thumbsup:
what about an add-a-leaf
That's what I did on my Cherokee and planning to do the same with the Comanche.
Added custom thick leaves and used cargo coils up front. I got 2 inches off it for a fair price without loosing any driveability.
It's a perfect solution I think without raising it too much.
