Front cross brace
I’m using a stock XJ towbar bracket that I found in the junkyard a couple years ago. It bolts inbetween the tow hooks and hook brackets. I’ve never seen another one since the one I found, but it wouldn’t be too hard to fab up something similar:
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Thats how most of the better tow hook kits come, including the factory ones.
RigidCo, also goes a step further by running a plate all the way across the front to strengthen the whole area. A piece of 6" wide plate will do the trick. Stay tuned for how I build my next stealth winch bumper :idea:
Nothing special but I made one to attach the tow bar to for when I flat tow. I'm using C4x4 Tow Hooks/Brackets than just added a cross brace to attach the tow bar brackets. I just used flat stock and than added a few bolts/spacers to tie it into the factory front cross-rail.
