atlnq9 Posted February 26, 2009 Share Posted February 26, 2009 Does anybody make replacement rear cab corner body panels? I have a source for rocker panels. Thanks, Andrew Link to comment Share on other sites More sharing options...
glundblad Posted February 26, 2009 Share Posted February 26, 2009 I needed two of them and could not find any. One side was good enough that the body shop was able to make it. The other side was too far gone. I had to purchase it from a junkyard for $40. Link to comment Share on other sites More sharing options...
Cdn Glenwood Posted February 26, 2009 Share Posted February 26, 2009 Can you let me in on your source for the rocker panels? Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted February 26, 2009 Share Posted February 26, 2009 :hijack: I bought them from NAPA in Quebec, Canada. Link to comment Share on other sites More sharing options...
atlnq9 Posted February 26, 2009 Author Share Posted February 26, 2009 here is the cheapest place I have found: http://www.showcars-bodyparts.com/cherokee.html They are cherokee but if you get the ones for 2 door then you should have plenty of length to modify. I was thinking I wouldn't find cab corners. The only comanche in a junk yard nearby is in terrible shape. Anybody know off the top of their head if any vehicles which have them available are close enough that they could be made to work? Basically something with almost the same radius curve? Link to comment Share on other sites More sharing options...
jpnjim Posted February 27, 2009 Share Posted February 27, 2009 I posted this on Pirate a while back: http://www.pirate4x4.com/forum/showthread.php?t=639718 Brand new ones (NOS) are less than $80 each: Outer cab corners: 57000859 $78.21 Cab - Side panel - Side panel - Outer Outer Left - Pick up, 1984-92 1984 - 1992 57000858 $78.98 Cab - Side panel - Side panel - Outer Outer Right - Pick up, 1984-92 1984 - 1992 punch part numbers in here: http://www.trademotion.com/splash/index.cfm?siteid=214086 They suck to cut out, without ruining them, well worth the $80. Looks like the website I posted has merged with another, and you can't directly punch in part numbers anymore (I couldn't atleast). I've gotten MJ rockers & XJ rockers from these guys, so I know they *used to be* good (hopefully they still are). If you can still get them for $80, here's what an NOS corner looks like (tucked away, and not for sale. :D ) Image Not Found Link to comment Share on other sites More sharing options...
atlnq9 Posted February 28, 2009 Author Share Posted February 28, 2009 It doesn't look like they have them anymore, bummer. http://www.parts.com/jeep/1991-jeep-com ... -parts.cfm It shows they have them but add it to your cart and it says part not found... You sure you don't want to get rid of that one! :bowdown: Just kidding, I wouldn't If I had them. Anybody else have a possible source? Link to comment Share on other sites More sharing options...
Wildman Posted February 28, 2009 Share Posted February 28, 2009 Finding body parts is.......well....... :nuts: Your best source is the junk yard :D No one's mentioned this place, yet........Shermans Here's another site that "might" have some parts......Mills If your willing to learn........made your own parts, it's not that hard, and for some tips, check out his site........http://www.autobodystore.com/ For the price of a piece of sheet metal ($26) you can make alot of body parts out of one sheet :bowdown: Most of the on line 'stores' use the same layout from Keystone, and it's hit and miss at it's best.......if you can set up an account at Keystone or Continental they might be able to track down some parts for you :dunno: Link to comment Share on other sites More sharing options...
