WyoCherokee Posted February 25, 2009 Share Posted February 25, 2009 will a D35 with 3.73's and disk brakes from a 97 Grand Cherokee bolt right up? :idea: or any D35 from a xj for that matter? I'm looking at a couple that are 100-150$ Link to comment Share on other sites More sharing options...
FitchVA Posted February 25, 2009 Share Posted February 25, 2009 edit: from the grand cherokee - nope. they use a coil/link setup instead of our leaf setup the xj - i believe the leaf perches aren't in the same location either Link to comment Share on other sites More sharing options...
mvusse Posted February 25, 2009 Share Posted February 25, 2009 With and angle grinder, welder and a pair of new perches the XJ can be made to work quite easily. I imagine the grand can too, but there'd be more stuff to cut off. A popular upgrade is a Ford 8.8 out of a 95 (?) and newer Explorer. Stronger axle, same bolt pattern, disc brakes. it is a bit narrower, though, so you might want to run wheel spacers. If I remember any of this information wrong I'm sure someone will correct me. Link to comment Share on other sites More sharing options...
WyoCherokee Posted February 25, 2009 Author Share Posted February 25, 2009 so for 100-135 should i go for it? i can do the fabbing. its no biggie to me. a couple of the said rear axles have all new brakes and everything. the Grand chero had disks...will that work ok? Link to comment Share on other sites More sharing options...
rtyler8140 Posted February 25, 2009 Share Posted February 25, 2009 I'm not a fan of rear discs. Just personal preference I guess. Well that and the fact that if you go through mud and muck, drums will do a little better job keeping the crap off of your brakes. Also depending on what you are going to be doing wheeling wise and what size tires you are going to run, the Dana 35 might not be beefy enough. The Chrysler 8.25 out of a cherokee is a good axle you could pick up decently cheap and is beefier than a 35. Just food for thought. But if your looking for discs, the 35 will be your cheapest option. GL with the install. Link to comment Share on other sites More sharing options...
WyoCherokee Posted February 25, 2009 Author Share Posted February 25, 2009 its just a DD, my 4x4 conversion plan will just be for functionality and nothing more. enough to get through the snowy days here in wyoming and the occasional long distance hunting trip. tires not bigger than 31's if even that Link to comment Share on other sites More sharing options...
offroader461 Posted February 25, 2009 Share Posted February 25, 2009 A d35 is a d35....a giant turd...don't waste your time...get an 8.8 if you really have a need for disks...you can pick one up for anywhere between $150-300 Link to comment Share on other sites More sharing options...
james750 Posted February 25, 2009 Share Posted February 25, 2009 I prefer duo servo drums in the rear rather than disc. If it were single servo (non self energizing) it would be a different story though. I will be putting a XJ 8.25 into the MJ soon and since I have to move that perches anyway I will be going with a SOA setup to get the lift. Link to comment Share on other sites More sharing options...
