rtyler8140
Everything posted by rtyler8140
I was thinking about re-gearing in the near future. Stock I have a Dana 30 up front and 44 in the rear with 3.54's and 33's.....yeah she drags a bit. I was thinking about going to 4.56's and maybe going up to 35's next time I need tires. I know I will need a new carrier for the Dana 30, will I need one for the 44 as well? I guess I'm trying to gauge how much $ I am going to need to get this all done. My mechanic will do all the work for me at a reasonable price, I just wanted to know what all I will need parts wise so I can price that. Thanks in advance. :bowdown:
Yet another SOA question
rtyler8140 replied to MJ is dead's topic in MJ Tech: Modification and Repairs
Depending on the condition of your leaf packs, your SOA conversion will yield different results. Id say a good average is 5-6", for some reason mine gave me 8.5". ZJ coils in the front will only give you an inch or 2 if I remember correctly (feel free to correct me if I am wrong). If you just want to clear 31's, you can just do a 2" budget boost (poly spacers go on top of your coils and longer shackles in the rear). Scratch that if your coils are no good. The ideal lift for 31's would be a 3" suspension that replaces your coils and also provides a new SUA leaf pack. In my opinion, your control arms will be fine will 3" of lift as well as your brake lines. I ran a cherokee with 4" of lift with stock control arms and track bar and it rode just fine and did great off road. Hope this gives you a little help. -
Call me crazy, but I would really like to lift the front of the MJ up a little bit more to match the rear. The front is 6.5 and the rear is about 8 maybe 8.5". I know I am flirting with the need for long arms at this point and would need them for sure if I went with 8" coils up front. I was wondering if I could use control arm drop brackets instead of going long arm? At this point I have adjustable upper and lower control arms, adjustable track bar, sway bar disconnects, a drop pitman arm, and transfer case drop. If the drop brackets are suitable in this case, will I need a longer front driveshaft as well? Also will the rough country drop brackets for an XJ work for the MJ as well? Thanks in advance for your help. Oh and Pete M.....I will put gears in this thing before I lift it anymore :dunce:
Depends on if you want to hack up your fenders or not. If you want to cut your fenders, you can do it with no lift (but thats a lot of fender to cut away). If you are not looking to cut the fenders, I'd say 6.5" of lift will be where you want to go to run 33's with no rubbing. Also with that tire size you need to get a rim with more backspacing so you don't rub your tires on the inside.
Hrm...It's a 1987 4.0L auto short bed. My mechanic did the soa and said I could probably use a little bit longer driveshaft, but as long as I don't beat and bang on it off-road it would be fine. I will have to throw some new U-joints at it and see what that does. (Pete is gonna love this part)...Probably doesn't help matters that I'm running 33's with stock gearing. :doh: I think I might be putting some 4.56's in pretty soon. Also, just out of curiosity, I currently have 6.5" of lift in the front and about 8" in the rear. Could I bump it up to 8'" in the front without having to extend the front driveshaft?
I've tried searching to no avail. I was wondering if anyone could tell me if there was a difference in length between a short bed driveshaft and a long bed driveshaft? I did a springover and have a slight driveline vibration and would feel more comfortable with a longer shaft. I was thinking if the long bed had a longer shaft, I could do that. If not, anyone have any suggestions? Thanks in advance.
1989 MJ : Project Ugly Duckling
rtyler8140 replied to FitchVA's topic in Member Projects: Your Comanches
Awesome job so far man. I actually went and looked at that MJ, but I needed a DD and didn't want to dd something that looked that brown. hahaha Glad to see you are making her look right. Hey you can also say that your MJ took 2nd in a tough truck competition. ;) -
Rust bucket or diamond in the rough? '89 Pioneer
rtyler8140 replied to wolfgraj's topic in Member Projects: Your Comanches
POR-15 Seems to be the sealer of choice round these parts. You are a brave man my friend, I'm scared of rust. haha -
Hey I scuffed mine with some sand paper. Be careful not to use too heavy of a grit as to not gouge the metal. Before: After:
If you are gonna drop $899, might as well buy this kit http://www.roughcountry.com/jeep_xj_6x.html I found it on ebay through Top Gunz Custom for $860 shipped. If you are able to do the spring over yourself then you aren't looking at any extra costs. Well you will have to get different shocks for the rear, but you will be able to sell the cherokee leaf pack and shocks. I'm very happy with this kit so far, it rides just like stock and has good flex.
Need to do something with your swaybar (disconnects are a good idea) and wouldn't hurt to put an adjustable track bar and drop pitman arm.
So I finally got to take her off road today. Shoe Creek is a pretty easy trail and close to where I live, so I went there. Got some 33's put on this morning and decided to break them in.
Welp I got her back on Thursday with the SOA all done. I actually got a lot of lift out of the rear. I think the rear is a few inches taller than the front. I'll let the pics do the talking. I'm sitting on 31's in these pictures.
Thanks Wildman :banana:
Hey fellas I was wondering if anyone knew what size brake shoes I would need for my comanche? I went to the parts store and they said that there were 2 different size shoes available. I'm sure I could take it apart and measure, but I was hoping to only have to take it apart one time. If it helps at all, its a 87 4.0, auto, chief with the dana 44 rear end. Thanks in advance.
I'm eventually gonna do that, I just don't want to deal with the holes in my door quite yet. haha
[quote="offroader461" Look almost like my 87 CHIEF I saw your MJ a while back and may have gained a little motivation from it. haha
So I finally got the lift kit and have the front installed and am waiting for my mechanic to do the SOA for me. I have some pics of the front on my build page in the other forum. So far I like it, but I haven't wheeled it yet to see what it will really do. Follow the build and I'll post more pics when I get it back. Thanks for talking me into waiting for a complete kit. :clapping:
So it's been a long time since I've updated. I just got a 6.5" lift kit through Rough Country. I got the Cherokee kit because it came with more stuff for the same price as the MJ kit. I was able to get it for $860 shipped to my door. I am doing a spring over in the rear so I don't need the rear springs. I spoke with my mechanic and worked out a deal for him to do the SOA in exchange for the leaf packs. I got the front done myself this weekend and dropped it off at his shop for him to get everything else done and aligned properly. So far I am happy with the kit and can't wait to wheel it. I only have 2 pics so far and they are with my cell phone. I will have more pics when I get it all done. It's sitting on 31's right now, but I am going to move up to 33's and sell these 31's in a few weeks. 6.5" up front and 1.5" in rear What it should look like after SOA (except tires will actually be on the ground)
coolant leak out side of cylinder head
rtyler8140 replied to mj2stay's topic in MJ Tech: Modification and Repairs
Had this happen in my Cherokee and talked with my mechanic about it. He told me it was basically a band-aid that could hold for 3 months or the life of the vehicle. Really just a crap shoot. Obviously your best bet is to replace the gasket, but if you are in a pinch, that stop leak will get you through. Just make sure you follow the instructions for best results. -
So I finally got around to putting a new O2 sensor in and it fixed my problem. Thanks guys. :bowdown:
Was just reading some old posts and figure that should be something to take a look at. I know how to pull my 02 sensor, but how should I check my cat?
Don't worry, I'm gonna run a swaybar. I've driven without one and it definitely takes getting use to in the turns, but as most of you say not worth it if you have to do an evasive move. I just got a new job making more money, so I think I'm gonna go with this kit and sell the rear springs and do my SOA. http://cgi.ebay.com/ebaymotors/84-01-Je ... |72%3A1171
87 Comanche with the 4.0L and auto trans. I have it switched onto the power setting, but I have no take off power. If I floor it, it will rev up and shift, then bog and sputter and rev back up. It acts as if it is getting too much fuel maybe? Within the last 6 months I have changed the plugs, wires, cap and rotor. The injectors all have new o-rings on them. I put a new exhaust manifold on it, but have an aftermarket intake so there is nothing hooked up to the tube coming off of the exhaust manifold. Is that causing my problem? I thought that was just to heat the air in the stock air box, but if that is messing with compression I guess that could pose a problem. Any help would be appreciated.
how do you get air out of cooling system?
rtyler8140 replied to J B Cuz's topic in MJ Tech: Modification and Repairs
I did a slightly different method when I changed my water pump. I just left the cap off of the overflow tank and then squeezed on my hoses several times with a pretty good amount of force and watched the air bubble out of the overflow. Keep pumping until you get no more bubbles.
