Any idea what trans this is?
http://www.novak-adapt.com/knowledge/sm465.htm
can be mated to a 242.
that low range might be awfully nice :)
(dumb question) the 242 as in the 4.0, or NP242?
According to Novak's website: both.
No, its not going into any of my trucks. I went to pick up some free 80's Vette rims from a local guy and he made me an offer I couldn't refuse. He called it a Muncie transmission but also said he wasn't sure so I figured I'd ask you guys. Now I know that it goes by many names.
Dang is that thing heavy. :eek:
I had meant the 242 as in the 4.0
The 4.0 shares the same bellhousing pattern as AMC small block motors, so it's actually pretty easy to get a belhousing to mate different transmissions to it.
Yeah that is what I was thinking. My father inlaw is a chevy fan and he has a mini junk yard behind his house. He has a couple 205's and 203's and 208's. I don't know how he got ahold of the 70 and some 9 inch rearend's but.. Anyone have any suggestions..
To do the 203/205 doubleris kinda on the expensive side... do you research. Also I am looking for a cheap NP203.... it seems everyone where I live wants an arm and leg for them.
I have a NP435, and np205 sitting on the ground by the garage... I pulled it myself :eek:
A NP205 weighs what? 106Lbs?
The 203/205 doubler is something you do only if you get the tcases for next to nothing. 203s are easy to find though. At least they are here...
The cost of T-Cases is the reason I'm trying to find a 4wd donor for my Toyota.
I thought a doubler was just the price of the plate pretty much. Like $300 or something. Seems like that's all the Yota ones are, but maybe the NP ones are different.
It's a new output shaft from the 203 range box that is shorter, and is splined correctly to mate to the 205. And a big assed peice of plate. And some bearings for the 203 output shaft (I think).
You could do it cheap and cut the 203 shaft down and respline it (if you know a place to get that done). But, then it's not induction hardened on the splines, so you just might tear 'em all off. Sure, you could get it induction hardened too, but unless you really know people it's cheaper to buy the kit at that point.
Yeah the plate to connect them is like 700. Thats the cheapest I found. Offroad design has a web site that has some info. I have a 4 wheel drive mag that has the whole write up on doing the combo. I guess I will be patient and see what happens.
By the time you do a 203/205 doubler, unless you do some kind of lower gear ratio in the swap (more moeny) you would have been better off buying a Terra lowkit, but if you are dead set on a doubler.. look at Mad rooster kit.. I know there is another kinda one... on PBB, but can't think of the manufacturer
