Need EGR Valve?
Since you don't have a location in your profile, I don't know if you live in an area that you are subject to emissions testing, but if not...then you can do away with it. There are kits made with a cover plate for the manifold, but I don't know off hand where to get them. I'm sure just a little Google searching will render you some answers on that :thumbsup:
I live in Yukon Canada, no testing here. If i did use the cover plate I remember reading that poor gas mileage may occur and/or a hotter engine temperature.
Anyhow I just order one for the dealer for 160 bucks with transducer and gasket.... Just in case.
Thanks for the replies
The EGR on my 89 4.0 failed before I did the stroker swap. All I did was plug the vacuum line going to the EGR valve with a golf tee. I never had any problems after that.
That's what I would try first. It's easily reversible if something does indeed go wrong. :thumbsup:
