Is it bad to invert leaves?
I had boggers and drove on the MJ to work one day and turned around and come home because it was such a rough ride i thought something was wrong. Have you had any road troubles with yours or do you even drive on the road.
Cole
Those tire don't touch the road. I tried driving around the block once and there were horrendous vibrations at ony 20 mph. But then I bought the 2 used boggers for trail tires anyway so it's not a problem.
Thats what i thought you would say. I have seen people riding the roads with them at 55 mph and i don't see how they can do it. I only got to 30 and thought my truck was going to blow up.
Cole
Cole
That's why my square driveshaft's like!!! Everything sounds like it's being bombarded with axes, mases, and battering rams, and everyone stares! Good back massage though.
that's just stupid.
Not only is the handling comprimised with that lift and tire combo, but the tires are probably only rated to 80. If it is indeed true, and I doubt it, then the tires would have leikely tread seperated, and he would have died.
Works for any tire.
Just, boogers aren't very round, so you have to use a lot of weight.
My 35 BFGs had about 1LB of BBs in each of them, smooth as a dream all the way up until I ran out of balls... No other weights or anything. And they were horribly unbalanced tires before then.
