manche Posted January 24, 2009 Posted January 24, 2009 i got a 89 jeep comanche 2wd 2.5l wanting to do a 4x4 conversion i found a ad for a cherokee 2.5l 4x4 does this sound like a good deal for parts? sale-1003538815@craigslist.org
mvusse Posted January 24, 2009 Posted January 24, 2009 :redX: Link is to email the seller, not the ad itself.
manche Posted January 24, 2009 Author Posted January 24, 2009 woops here the right link http://phoenix.craigslist.org/nph/cto/1004244771.html
mvusse Posted January 24, 2009 Posted January 24, 2009 That Cherokee seems to have an AX4, and thus should have 3.55 gears. You have an AX5 and should have 4.10 gears. 3.55 is going to suck if you go larger tires, and even with stock tires might make 5th gear useless. You want at least 4.10, but probably 4.56 (from a 4 cylinder/auto?). Still, for $650 it's a good deal for the transmission, transfer case, front drive shaft and all the bracketry and stuff. I believe you can take 5th gear out of your AX5 and install it into the AX4 to make it into a 5, but pm JeepcoMJ to be sure. He's had enough of those apart to be able to build one with his eyes shut. Sell fenders, doors, grill etc. to get the money to get a 4.10 front axle from a JY and scrap what you can't sell. You will have to take your current 2wd rear drive shaft to a shop to have it shortened.
manche Posted January 25, 2009 Author Posted January 25, 2009 can i still use my ax-5 if i get 4.10 rear and front
manche Posted January 25, 2009 Author Posted January 25, 2009 name all the stuff ill need to do this conversion also if i just decide to temp run the dana 35 with 4.10 on the dana 30 3.55 will i will be able to drive it with 2wd till i get tranfercase and tranny hooked up
mvusse Posted January 25, 2009 Posted January 25, 2009 A 2wd transmission will not bolt up to a transfer case, so no, you can't keep your current transmission. Every time someone has tried to make a list of what all is needed for the swap, 2 or three people chime in with little things that were forgotten, and it probably still would not be complete. The main stuff is easy, transmission, transfer case, drive shafts, axles. But then there's the rest of it: control lever, linkage, console mount etc. Best way to do it is to have the entire donor sitting beside your truck. If there's anything you forgot about you just take it off and put it on. That way you can also see how things fir together. It's a lot better than coming home with a bed full of parts trying to figure out how the puzzle fits together.
mjeff87 Posted January 25, 2009 Posted January 25, 2009 It's a lot better than coming home with a bed full of parts trying to figure out how the puzzle fits together. Now where's the fun in that??? :rotf: Jeff
manche Posted January 25, 2009 Author Posted January 25, 2009 i know i was wondering if i can put the front axle and diff on with a 3.55 front and 4.10 rear till i hook the tranny and case
Pete M Posted January 25, 2009 Posted January 25, 2009 Why on earth would you go through the effort of swapping in the front axle when you can't use it? Just leave the 2wd one in there. And I would pass on that Jeep and keep looking for one with the AX-5 so you'll have everything you'll need rather than just some of what you need. A 4.10 Dana 30 is probably the hardest part to find on the list.
