mark_moz Posted January 19, 2009 Share Posted January 19, 2009 i recently purchased a 1987 jeep cpmmanche pickup and i have replpaced some wiring and installed a new alternator and battery theni replaced the ignition module and ignition coil but it still cranks and doesn't start anyone have any suggestions, also if you know where i can get a parts magazine online please help me. Link to comment Share on other sites More sharing options...
mvusse Posted January 19, 2009 Share Posted January 19, 2009 Crank position sensor/ Link to comment Share on other sites More sharing options...
tallon2064 Posted January 19, 2009 Share Posted January 19, 2009 You can try here for your parts and service manuals: http://www.greatlakesxj.com/tech.html Hope this helps Link to comment Share on other sites More sharing options...
bigd44889 Posted January 19, 2009 Share Posted January 19, 2009 :agree: cps Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 19, 2009 Share Posted January 19, 2009 If your problem is no fire...then I agree... CPS Link to comment Share on other sites More sharing options...
jake Posted January 19, 2009 Share Posted January 19, 2009 I just went through this myself with my '88 Comanche. You can test the CPS with a multimeter, set for ohms resistance, you should have about 250-500 ohms. Mine was at infinite which means open circuit. I found this site which gives very good directions for testing your Renix system: http://www.lunghd.com/Tech_Articles/Eng ... ostics.htm Autozone has the CPS for about $32.00. Also, you may want to check the fuel pump relay...mine needed both the CPS and the relay. Jake Link to comment Share on other sites More sharing options...
WyoCherokee Posted January 20, 2009 Share Posted January 20, 2009 don't forget your ground strap. a bad one or disconnected won't allow it to fire either Link to comment Share on other sites More sharing options...
Sir Sam Posted January 20, 2009 Share Posted January 20, 2009 comanche* (don't worry, we all do it) Link to comment Share on other sites More sharing options...
