Coil Springs and leaf springs
well the easyist way is take it to some one and pick it back up
but if u want to be like most of us u got to do it your self so
when i did mine i unboted the contol arms ,steering link and drag link
oh jack truck way up and put jack stands under rails use floor jack for the axle
lower axle till u can pull springs
put new ones in and jack back up reconect everything
if u have a spring compesor u can use it and not have to diconect everything
for the axle to drop so far
oh take out retaining bolt at the bottum of spring
rear is easy
jack up body and suport it use floor jack under diff put a little pressure on axle
take off u bolts
lower axle
use clamp to hold spring together
take out centering pin
losen clamps add your leaf clamp back together
put in new centering pin
move clamps jack axle back up to springs but a little presser on springs
put on new u bolts
iff i missed anything i'm sure some one will tell us
have fun now :cheers:
