project88mj Posted December 24, 2008 Share Posted December 24, 2008 ive looked a lot and i can not find the link that shows the costs layed out part by part. if any one knows of a link or two please post them up. I'm starting to get ready for my stroker :brows: Link to comment Share on other sites More sharing options...
GaruMJ Posted December 24, 2008 Share Posted December 24, 2008 http://www.rockcrawler.com/techreports/ ... /page2.asp HOpe this help you :thumbsup: Link to comment Share on other sites More sharing options...
Boilermaker Posted December 24, 2008 Share Posted December 24, 2008 Dino's stroker page (sample builds with estimated HP, no costs): http://www.jeep4.0performance.4mg.com/stroker.html Try the project threads over at jeepstrokers. A couple of guys have long detailed threads with their parts lists and what they paid. Here's an example of one of the more detailed project threads: http://www.jeepstrokers.com/forum/viewt ... p?f=8&t=71 If you haven't already spent some time over there reading (or better yet joining), i would highly recommend it. Link to comment Share on other sites More sharing options...
project88mj Posted December 25, 2008 Author Share Posted December 25, 2008 some one a while back posted a link that showed that the total cost was just under $2000 i think it was like $1,983 or somthing? any ideas? Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted December 25, 2008 Share Posted December 25, 2008 I total cost built mine for right at $1600 -junkyard block - $60 -Machine work (bore, hone, cam bearings, hot wash, and pressure test) with pistons - $500ish -Crank - $200 new -rods - $125 reconditioned, shot peened ect -misc engine parts (water pump, oil pump, timing set, ect) - $200 -2000 intake - $25 -injectors - $50 - used LT1 injectors from a camaro -oil, fluids, ect - ? I have the reciepts in P-cola I will have a look at them when I get home from the holiday. It can be done for much less that you think without skipping steps. I reused my stock cam since it was the 1991 HO cam. Boss did a three angle and lapped the valves on the old head, he also re-seated and shimmed ll the springs and checked the head to be level, for free. I think some of those values are off, but the total build was right at that price, I will make a spread sheet when I get home and post it. $1600 went from the blown motor to a running driving jeep. Link to comment Share on other sites More sharing options...
ejndssn Posted December 25, 2008 Share Posted December 25, 2008 if you are looking to do this your self look at these dino's site, hesco and clifford should give you some ideas of what it would take :brows: then look at what the wolfpackjeeper provided as a rough list to go by and shop around your area to see what i cost to get some of that stuff done. for the price that your looking at there was a guy who has done a 4.5l stroker on the 4x4bc web site i think his name was bruce. and you may want to look at kits i got my from accurate power at the time they where selling them. what i did was do the research find out what it takes based on your budget. Good luck Link to comment Share on other sites More sharing options...
comanche87 Posted December 26, 2008 Share Posted December 26, 2008 Hey. What be the cheapest cost to build a 4.5L stroker? Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 26, 2008 Share Posted December 26, 2008 Hey. What be the cheapest cost to build a 4.5L stroker? Ya'll are asking questions that there really is no straight answer to. The cost of building a stroker is going to have many variables such as what parts you need vs. what you have, what brand of parts you use, how much work you can do vs. what you have to pay to have done etc, etc... I have seen strokers built for $1500 - $1800 and I have seen them go over $4000... If you really want to get in to all the detailed info on what you need and costs, the better place for that is here... http://www.jeepstrokers.com/forum/ :cheers: Link to comment Share on other sites More sharing options...
ejndssn Posted December 27, 2008 Share Posted December 27, 2008 :agree: x2 what BLHTAZ said not only that but there may be some links to help you decide the way to go Link to comment Share on other sites More sharing options...
armybmbsqd Posted December 30, 2008 Share Posted December 30, 2008 I think I ended up with about $3500 into my stroker. That was including header, new valve cover, new oil pan, ceramic coating on header and intake and a whole lot of little parts. :yes: Link to comment Share on other sites More sharing options...
