the never ending story, just ended
  • Replies 168
all wired up and after about 15 mins of playing with the license plate i have made my decision :chillin: ,
tested it and it works :D , don't know if i can pull anything yet, i need an excuse to use it :shake:
ran the ground wire to my tailgate, its out of site for the most part, and if needed i can move it else where when the tail gate is removed,
here's so more pics to keep you tied over, I'm going to shambhala soon so I'm tied up for money at this moment, but when i get back i should have some more to invest into the truck.
next up fixing my oil leak once and forall
I'm starting to really enjoy your build-thread. and thanx for your help earilier tryin to figure my fuel pump prob.
thanks :D and any time :cheers:
yesterday i removed my lifter cover ,
then i got a bit distracted,
so today i made tripple sure i won't have an oil leak,
put make a gasket then gasket then make a gasket on,
letting it cure and will start her up tomorrow.
now my next project,
clean all of the contacts up to see if it'll fix my gas gauge
lug nuts replaced :D
more bling :D
was going to do some painting and clean everything inside but, I'm short on cash atm,
so i just did what i could with what i got for now :D
but as always more too come,
just need a day to go get it
well i sanded my ground for more connectivity,
see if that will help, checked the wrap all the way to the adapter,
and then checked the plugs in the adapter, everything was good,
was going to pull a sensor or something off, but gas started coming out, i forgot that i had a full tank :shake:
can't check it till after work tho, my seal is still curing on my valve cover
then i got bored of that and pulled out the angle grinder,
my plan is to get autocad and work on a new cross member for the frame rail, get that made,
get a spot weld driller and take the old one off, and put the new one on :D
restore it to its original state :brows:
so earlier on i pulled up my floor boards to find this
so i did this :)
started chopping
look at all that rust!
this picture is relevant because it is proof that i put my sweat and blood into her jamminz.gif
all cleaned up :yes:
and mat back in its place for now
so took it out today,
and she ran great :) no leaks from my transmission, or oil!!
i guess i got my power steering a bit hot because it leaked a bit, other than that it seems to be fine.
i love how smooth the steering wheel is, and i got a suede cover so its like a cloud :yes:
i have to replace the pinion seal, :fs1:
but hey its expected, 24 year old seals will go at somepoint,
this is going to be fun i can tell you that XD
tomorrow i will take er out and do a bit of offroading and take a stance shot :D
downloading the program,
i will design it once i install it,
I'm debating if I'm going to get it made from a single piece,
or, go down to my buddy's and get it welded up, with some "cardboard" (paper) cutouts,
but either or i will get them made atleast 2 weeks away or longer,
5 more days I'm going to shambhala!! :yes:
http://www.shambhalamusicfestival.com/
i noticed my power steering pump has a leak,
o_O so i need a new hose, its the one with the sensor on it,
any one got the oem replacement number?
haha gotta love freebies :brows:
part of a grad present from my mothers friend, plus some cash :D
my new shiny exhaust (+9 feet of straight pipe, gotta love em :D ) :banana:
new tach
shifter
and my new door knobs :headpop: :wall: so much for Chrysler replacements, didn't even fit
as allways more to come,
installing autocad as i type,
will start working on designing the cross-member tomorrow :D
hope the pics will tide you over (yea right :shake: )
so i installed the shifter knob today,
since i sheared the knob right off i needed one i didnt have to screw on,
3 bolts and it was on,
screwed the cover back on,
final product.
tomorrow i will get the exhaust mounted and installed at a buddies shop 2 towns over
got my winch re-wired
:fs1: damn guy drilled a hole thru my good floor board :wall:
all strapped down
no more chafe
look what i found?? what would the use of this be? its not on the other side either
and at the back
exhaust
10 feet of straight pipe
where the cherry bomb use to be
no more rattle
and here she sounds, (lol forgot to turn on the truck while recording, voice is muffled at the end)
I'm thinking about running it :P
or selling it :brows:
got some upgrades done,
theese speakers blow my other ones out of this world, don't even need to use my boom box any more,
they are perfect for my stereo too, max 200W per speaker and my deck is max 200W as well :D
so it comes out clean and clear, no more power surge problems, must have been the old speakers :D
and no need for an amp or capacitor yet.
and holy i previewed this post like 3 times, i thought i posted it,all thru the day i come sit down and I'm like wheres my post? LOL
so my neighbor is moving,
and she gave me a 1977 cordoba without the papers,
we also got a Cadillac from her as well but that has papers,
v-8 comanche? i think so :D
i think with that engine, i will be able to run my dually rear axle?
think its about time for an update :D
installed an int light,
will have pic of it in daylight tomorrow
:chillin:
got some fluids for her
part of my leaking powersteering
donor vehicle :D
and putting her to work, first load uppon many too come, didnt even make a dent in the pile,
and there is 3 of them
Great job on the detailed pics.
I would move the ground cable for the winch, the tailgate does not have a good contact with the chassis. Attach the ground to the chassis after cleaning the attachment point.
i thought about that one, so i relocated it to right here :D
but i took my truck to the carwash :headpop:
forgot to disconect the winch :wall:
it only comes out now :fs1:
my int light as promised,
just a simple battery powered swivel light you can get at wally world for ~$10 :thumbsup:
(and yes i have to wire wheel that factory glue(rust) off, and neutralise it^^)
hauling more wood
the pile so far(about 5 truck loads is there, still gots a load in my truck) and that was just the first wood pile :shake:
she worked hard, so i think she deserves a treat :)
got some the covers for the speakers, had fun gettin em on, covers my door up a bit better :rotf:
as allways more to come :D
