oldrusty Posted December 14, 2008 Share Posted December 14, 2008 The poulan saws are good but they do make two lines. The green poulan saws are the homeowner line and are the lesser versions perfect for occasional use. If you are going to use the saw on a more regular basis look into the poulan pro saws ( yellow in color). They are manufactured with better engine internals and are designed for more use. Lowes and homw depot used to sell one with a 16" bar for about $130.00. Link to comment Share on other sites More sharing options...
Car RamRod Posted December 15, 2008 Share Posted December 15, 2008 The newest saw I have is an 18" crafsman. For a year or two it was finniky on starting, till finally it wouldn't start. I reverse the primer bulb and its been great ever since. It's a good saw for how I use it (firewood and such), but if I used a chainsaw more than 15 times a year, I'd probably go for something better/bigger. Link to comment Share on other sites More sharing options...
mfpdm Posted December 15, 2008 Share Posted December 15, 2008 BLHTAZ said: aemsee said: mfpdm said: I've got the poulan wild thing. It's been a great saw. Has never let me down and after awhile you find the tricks of keeping the chain tight. I still have to tighten it but not near as much. Here's lowes add. http://www.lowes.com/lowes/lkn?action=p ... lpage=none Well, mine is the wild thing as well, and please share the secret for keeping the chain tight :bowdown: That's what I have too. I keep buying new chains...even the expensive ones thinking that it was the chain stretching because I didn't buy a good one, but they still will not stay tight for more than 5-6 cuts... :shake: Well you need to get a ..... nah I won't BS yall. :D Basically it's keeping the chain sharp, well oiled, and not trying to force the saw. As someone said above this is the home owner version so take it slow. I've have two chains and swapp them every once in awhile but have a little hand sharpener that keeps them sharp. Takes about 5 mins to do the chain on the saw. Don't get me wrong I still have to tighen it about 2-3 times per tank of gas. It will also depend on what type of wood your cutting. Sappy ole pine is the worst for loosening the chain. I use it probably 3-4 times a year. More if we get a hurricane. I've pretty much cut all the neighbors un-wanted trees down, so it's sees less and less use. That and I'm getting to old to get my @ss up the tree to top them out. :D Oh yeah, if I did a lot more cutting, I'd get a husqvarna. Best saw out there for the professional IMO. :cheers: Link to comment Share on other sites More sharing options...
Akula69 Posted December 15, 2008 Share Posted December 15, 2008 Got a Poulan 'Wild Thing' 18" bar right after Katrina and it has always worked well...starts right off every time. I do have the problem with the chain coming off the bar occasionally, but have gotten into the habit of tightening it after each cut so I don't have the aggravation of the chain flipping me off, I mean flipping off the bar... :mad: Link to comment Share on other sites More sharing options...
jtdesigns Posted December 15, 2008 Author Share Posted December 15, 2008 Well got a update for yous... I went to Lowes and tractor supply, compared notes and what you guys had to say, I made a choice. I got a Poulan Pro from Lowes with a 18" bar. >>>Link<<< Brought it home fueled it up and filled with bar oil. Followed the directions and started right up!! :clapping: Its a sweet saw, I so about bought a Husqvarna,,,but.... I had to squeeze my cheeks on the price, kinda funny cause I was sweating it pretty hard.. Didnt get to cut anything with it though... :( But I'm done with my Monday class!!! soooo going go get some heat tomorrow.. Woot-woot!! Thanks for all y'all input!! Now......................................... How I use this thing?????????????? :hmm: :rotfl2: joke'n :yes: Oh the only thing I wasn't happy about this saw is it doesn't have the metal spike plate at the base of the bar... What the correct name for that metal spike plate anyways??????? Link to comment Share on other sites More sharing options...
oldrusty Posted December 15, 2008 Share Posted December 15, 2008 Most of the smaller size saws don't come with the spikes you usually have to get into a larger saw to get them. I used to work for a place that sold the poulan pros as well as echos and huskys. The husqvarnas wer bad @$$ saws but were considerably more money both in purchase price and parts than the others. The poulans and echos were both excellent products. Link to comment Share on other sites More sharing options...
jtdesigns Posted December 15, 2008 Author Share Posted December 15, 2008 It looks like there's a bolt pattern there where the spikes would be, so I was hoping I could order one or something.. :dunno: Link to comment Share on other sites More sharing options...
jtdesigns Posted December 15, 2008 Author Share Posted December 15, 2008 Is it called a spur kit??? Link to comment Share on other sites More sharing options...
Akula69 Posted December 15, 2008 Share Posted December 15, 2008 It's called a Bucking Spike. See here: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110323508868&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX_Stores&refitem=120335776445&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget&_trksid=p284.m185&_trkparms=algo%3DSI%26its%3DI%252BIA%26itu%3DIA%252BUCI%26otn%3D4%26ps%3D42 :cheers: Link to comment Share on other sites More sharing options...
Akula69 Posted December 15, 2008 Share Posted December 15, 2008 Jeez...how do you shorten a URL? :oops: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 15, 2008 Share Posted December 15, 2008 Akula69 said: Jeez...how do you shorten a URL? :oops: This is the format... [url=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110323508868&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX_Stores&refitem=120335776445&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget&_trksid=p284.m185&_trkparms=algo%3DSI%26its%3DI%252BIA%26itu%3DIA%252BUCI%26otn%3D4%26ps%3D42]See here:[/url] ...to create this... See here: :cheers: Link to comment Share on other sites More sharing options...
jtdesigns Posted December 15, 2008 Author Share Posted December 15, 2008 Hey thanks Akula! :clapping: Just waiting for them to answer my email! :thumbsup: Ebay has everything don't they??? Link to comment Share on other sites More sharing options...
