a few buddies of mine were trying to figure out what was wrong with my clutch
and so the started to unbolt the master cyl,
simple enought right?
well they dropped a bolt in the engine and it is lost,
probably never to be seen again,
what is the bolt size? threading?
(looked in the bolt thread couldnt find it)
I'm not entirely certain of what you're trying to describe. In the engine? Do you have a picture? I'm pretty certain that every bolt you drop anywhere in the truck must be retrieved or it could cause horrible problems. :(
no they dropped it around the distributor,
spent over 2 hours looking 4 it lol,
so i need to get the measurment for a replacement bolt,
ill get a pic of it up tomorow,
(its where u fill up your clutch line with dot 3 fluid,
top right corner under your hood)
Is yours a right hand drive? That's the only way it would be on the right side of the firewall...
Wouldn't it be easier to just take the other one to a store and match it up?
